Old 05-13-2009, 05:37 AM
Jonne is on a distinguished road
Fanuc encoder lines C1, C2, C4, C8...
Fanuc encoders have resolver lines C1, C2, C3, C4. Is that data in
normal bit format or gray code? I need to change that resolve lines
compatible for Omron servodrives some TTL-McGyverning...
Old 05-13-2009, 09:01 AM
Al_The_Man's Avatar
The C1 - C4 lines are a binary pattern than is used by Fanuc to produce a Pseudo Sine wave for AC commutation.
I had no success in translating the pattern in order to convert to BLDC to simulated hall effect as the pattern does not allow coincidence with the BLDC timing.
I ended up replacing the encoder with one with BLDC 8 pole timing pulses.
Renco have some on eBay right now for $20.00.
Old 05-13-2009, 03:23 PM
Let's think. Copy C8 straight to A-channel.
B-channel = C4 XOR C8
CCCC Channel
8421 A B
0000 0 0
0001 0 0
0010 0 0
0011 0 0
0100 0 1
0101 0 1
0110 0 1
0111 0 1
1000 1 1
1001 1 1
1010 1 1
1011 1 1
1100 1 0
1101 1 0
1110 1 0
1111 1 0
0000...1111 = one full rotation
So we have now get quadrature pulse in A & B ( or R & S ) -channel.
Why that can work? Is there something what I miss?
PS. My servos are AC
Old 05-13-2009, 05:16 PM
Al_The_Man's Avatar
It depends what you are trying to achieve, I wanted to use the Fanuc Red Cap (AC) motors with a BLDC analogue input drive.
I could not get the binary pattern to coincide with the required armature angle to provide commutation at the right time.
The Fanuc encoder is keyed to the shaft so apart from a few degrees adjustment, the encoder position is fixed.
If you can come up with a BLDC solution, that would be great.
Old 05-14-2009, 01:37 AM
Oh, it is not normal bit code. I have to think that more.
Do you have more datasheet about Fanuc encoders? I'd
like know where Z-pulse is located conserning C1...C8.
Old 05-14-2009, 09:02 AM
Al_The_Man's Avatar
The motors/encoders I have played with so far have a standard quadrature encoder with marker pulse, the four C1-C8 are extra tracks on the disk used for Fanuc commutation.
So I have the encoder output, I just need the BLDC comm. signals.
Ala http://users.tinyworld.co.uk/flecc/4...otor031102.swf
Old 05-15-2009, 12:39 AM
jmelson is on a distinguished road
I just developed a converter for these motor/encoders. The way I have it set up, it uses the 1-2-4-8 signals at first, until it sees the encoder index pulse, then switches over to counting the quadrature signals from the encoder. I have a simple 6-step drive that uses standard Hall signals, and this converter allows it to work with the Fanuc motors. This converter should work with any other drive than expects the Hall signals, as well.
I will be demoing a prototype at the EMC Fest in Wichita May 21-27, and should have a finished product out by the end of June or so.
Jon
Old 05-15-2009, 12:42 AM
CCCC Channel
8421 A B
0000 0 0
0001 0 0
0010 0 0
0011 0 0
0100 0 1
0101 0 1
0110 0 1
0111 0 1
1000 1 1
1001 1 1
1010 1 1
1011 1 1
1100 1 0
1101 1 0
1110 1 0
1111 1 0
The codes are not a straight binary counting sequence as you have written above.
It starts out like this :
0011
0010
0000
0001
etc. It is a form of gray code, where only one bit ever changes state at a time.
Jon
Old 05-15-2009, 02:09 AM
Wait a minute... When I use AC servo do I need any HAL-outputs?
Old 05-15-2009, 08:28 AM
Al_The_Man's Avatar
With DCBL just the three commutation pulses are needed.
For AC sinusoidal, there appears to be at least two methods, one is to use the three BLDC commutation pulses initially to detect the position of the armature, after which the differential encoder is used for the subsequent commutation.
The other method uses a two phase resolver only.
Old 05-15-2009, 08:33 AM
Al_The_Man's Avatar
Jon
I would be interested in knowing more about the converter, is this built into a drive or is this a circuit module that goes between the motor/encoder and any BLDC drive for example?
  #12   Ban this user!
Old 05-15-2009, 11:04 AM
Right now, it is a separate module. I may eventually build it into a version of my drives. But, what I have so far would be a separate module that would go between the Fanuc encoder and a standard drive. I make my own brushless drives, and they take the standard Hall signals, so I need a converter for any motor/encoder that doesn't produce those standard commutation signals.
Jon
Fanuc 6M: Sudden simultaneous 416, 426, 436 (Encoder or Resolver) alarms. Deltic_Engine Fanuc 7 07-02-2009 10:11 PM
Fanuc 6M Encoder cable issue Yabbos Fanuc 6 12-02-2008 07:38 AM
Fanuc 3m encoder disconnected error nathanclymer Fanuc 13 08-25-2007 07:57 PM
Fanuc servo / encoder problem Andy Fritz Servo Motors and Drives 11 10-15-2006 12:44 AM
Fanuc 6M start lines TR MFG Fanuc 6 09-10-2005 05:17 PM
