IVe been trying to send & recieve. Sometimes it works but most time i get alarms (085, 086 & 087) 086 being the most common. All leads & plugs have been replaced & and terminated as per specifications. Sometimes when sending i will get LSK flashing but will not recieve anything. All paramaters within the controller & computer remain unchanged. This problems seems to be intermittant.. Works one minute but not the next. ![]() The controller is used on a Supermax V105A mill. Any help would be greatly appreciated.. Danny |
Wired as such: 25pin/9pin 2/2 2/3 7/5 25 Pin side 4 - 5 bridged 25 Pin side 6 - 8 - 20 bridged Used parameters in both Mastercam Editor & Gibbs Editor Baud: 4800 Data bits: 7 Stop bits: 1 Parity: Even Flow control: Xon/Xoff Xon Xoff characters: 17/19 Controller settings: 0002 - 1 0552 - 10 TVON - 0 ISO - 1 Input I/O - 0 |
| Is that a typo? Should be pin 2 -2 & 3 -3 Al.
| I would connect the shield to pin 1 on the 25-pin side. Dan Fritz recommends NOT jumpering 6-8-20, but instead jumpering 6-8 on the 25-pin side and connecting them to pin 4 on the 9-pin side. This can help with 086 alarms. Also, in Windows Control Panel, go into the System - Hardware - Device Manager - Ports (COM & LPT) - right-click on the port you are using. Under Properties, Port Settings - Advanced, turn off the FIFO buffers. This may help with the 085 and 087 alarms. |
| go to radio shack.. buy a 5 foot rs232 cable.. buy a null modem adapter and a the converter to 25 pin.. and ur set.. should cost you about 20 bucks... if you still are having problems you and you have a memory board on this machine that its bad.. if no memory board then its the main board.. also check the cable running form the electrical panel to the cnc to see if its in good shape.. |
I'll post again later today after trying all your solutions. Many thanks for the advice guys! |
| Try to make DNC cable according this article (full handshake): http://www.aggsoft.com/cnc-dnc/fanuc-0m.htm It works with my Fanuc O-MF and DNC precision software. Regards, Dan |
| Have you tried a different computer? I have worked with some with weak com chips. I have also had weak chips on the fanuc board. I used to be able to get the chips from Radio Shack. You'll have to go to Digi-Key now. One machine picked up RF from the shop incoming lines and blew the com chips every year or so. I finally put in plugs and just swap them out. As for the computer, you may be able to access com 2. Check the settings in the DNC software and move the plug to the other serial port (if you have two). Robert |
#10
| You said that parameter 002 was "1". Does that mean it's set to "00000001" ? If so, then your CNC is set to 2 stop-bits, not 1 stop-bit. You can set the DNC software to 4800 baud and 2 stop-bits, or you can set parameter 002 to all zeros. It doesn't matter whether you use 1 stop-bit or 2, but the CNC must match the PC. I recommend you set parameter 002 to "10000000", and the PC to 4800 baud + 1 stop-bit. Jumpering 6-8-20 should be OK on the Fanuc 0, but we did encounter problems on the faster 20i and 30i controls. On those we recommend connecting pins 6 and 8 on the PC to pin 4 on the PC side. |
| Fanuc 6mb drip feed issue | dhunter1220 | Fanuc | 2 | 02-27-2009 02:58 PM |
| Fanuc 6M Encoder cable issue | Yabbos | Fanuc | 6 | 12-02-2008 07:38 AM |
| Fanuc 0M, M19 Issue.. | gearsoup | Fanuc | 14 | 09-14-2007 12:09 PM |
| Fanuc Drive Board issue | Joseph Souza | General CNC (Mill and Lathe) Control Software (NC) | 1 | 09-09-2007 01:53 PM |
