Old 05-11-2009, 03:20 AM
FastCut is on a distinguished road
Fanuc 3M-C controller
A couple of months ago, I purchased my first CNC machine, a Kira KV-3MC Machining Center with a Fanuc 3M-C controller. The seller led me to belief that all the manuals were included. I received none. Luckily, I was able to get the parameter settings from Kira Japan, but have had absolutely no luck in locating any other documentation for machine or controller.
Batteries on controller were dead upon arrival. Replaced them. I still get two alarms: "P/S Alarm 100" & "Servo Alarm 02 (VRDY)". Tried clearing with holding "CAN" and "P" down while powering up, but nothing cleared.
Can anyone please help? Manuals would help a lot, because I have no experience with cnc controllers.
Thanks in advance.
Old 05-11-2009, 03:35 AM
Dan Fritz is on a distinguished road
Alarm #100 means that the Parameter write/protect switch on the main board is on. That switch is designed to prevent you from changing parameters by accident. You must turn off that switch, then hit RESET to get rid of the alarm and run normally.
The VRDY alarm means that one or more of your servos isn't coming up ready. When you release E-stop (or just power up the control without E-stop), the big MCC contactor on the back of each drive unit should pull in with a "thunk" and the motors should come under power. If the contactors never pull in, that's a problem on the CNC (maybe you're in E-stop). If the contactors pull in, then drop off again, that's usually a servo problem. It's also possible that your control is never coming out of E-stop for some reason. Look to see if an overtravel switch is on or stuck. There are usually two sets of overtravel switches. One just give the OT alarm and lets you back away, the other puts the control into E-stop and disables the servos. That's a "backup" safety switch in case the servo simply runs-away. Most machine tool builders wire all these extreme OT switches in series, so if any one of them is actuated, all the servos shut off and you stay in E-stop.
Hope this helps.
Old 05-11-2009, 05:48 PM
Dan,
Thanks. Your advise surely helps. The parameter switch was indeed switched on. The whole spindle head was lowered, by hand, to facilitate shipping. This may have put limit switch in E-stop position. I will check on this and let you know if things fall into place.
I still need to get an operations manual. Any idea where?
Regards,
Mike
Old 05-11-2009, 11:52 PM
fanucman is on a distinguished road
Originally Posted by FastCut View Post
Dan,
Regards,
Mike
yep.. check the overtravel switches first.. if you have other problems just call fanuc they have a bunch of good guys working in the service department and they dont charge for help.. they also sell manuals...
Tags
fanuc 3m-c controller
Fanuc 18i-M controller Wjman Machine Problems, Solutions , Wireless DNC, serial port 9 10-01-2010 12:02 PM
Help with MDI in Fanuc 15-m controller Barnowl General CNC (Mill and Lathe) Control Software (NC) 6 04-06-2009 12:58 PM
Fanuc controller? mwood3 Benchtop Machines 2 06-18-2008 06:35 PM
Fanuc 10T F Controller adaptaflex Fanuc 10 01-28-2008 12:51 PM
fanuc 10t controller merv385 Fanuc 1 02-18-2006 10:52 AM
