Results 1 to 5 of 5
Thread: Drip feed for Fanuc 0-MF
    Jan 2007
    greece
    Post Drip feed for Fanuc 0-MF
    Hello guys,
    Recently we took a CNC machine(KRYLE) with a controller Fanuc 0-MF.I want to use the drip feed method of transfering,but I can,t understand the parameters that I have to change.I connected the PC with CNC but I can only transfer all the program.On CRT show TAPEF=0 and I think that I must turn it to TAPEF=1 to have a DNC connection.Which of the parameters must change to achieve the drip feed transfer?If anyone knows the procedure,I would like to have some help on that subject.
    Thank you
    Registered dcoupar's Avatar
    Mar 2003
    I believe TAPEF enables F11 style (single line) multiple repetitive cycles, and has nothing to do with drip feeding.
    Jan 2007
    greece
    Thank you,dcoupar.It seems that I don't know a lot of things,but is there any chance to help me with some informations about drip feed
    Registered SINUMERIKO's Avatar
    Sep 2008
    Home sweet home
    Here's what you're looking for, but for a Fanuc 0M, perhaps you'd like to give it a try.
    Attached Thumbnails Attached Thumbnails Drip feed for Fanuc 0-MF-fanuc_0m_df.pdf
    May 2005
    VietNam
    Quote Originally Posted by giorgis View Post
    Hello guys,
    Thank you
    Usually you should have Tape or DNC position on mode switch on control panel. In DNC mode, diag 127#5 must be 1. This bit could be 1 only when machine uses PMC. If your machine uses PMC (L or M) you can check on ladder screen if it has G127.5 coil. if you can't see this coil then your machine may not drip feed.
    1. Need Help!- Drip feed mode with Fanuc OMA
      By visu in forum Fanuc
      Last Post: 06-26-2012, 08:50 AM
    2. Fanuc 6mb drip feed issue
      By dhunter1220 in forum Fanuc
      Last Post: 02-27-2009, 03:58 PM
    3. Need Help!- Fanuc 6mb drip feed
      By cowleym in forum General Metal Working Machines
      Last Post: 03-18-2008, 06:25 PM
    4. Drip Feed - DNC - Fanuc 16i
      By gm3211 in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 09-21-2007, 03:43 PM
    5. Drip Feed Fanuc 18i
      By MoldMaker in forum Fadal
      Last Post: 12-26-2006, 11:56 AM
