Old 05-06-2009, 04:19 AM
Salamat is on a distinguished road
Fanuc18-GC
We have a grinding machine with Fanuc 18-GC controller. The power supply unit was defective. It is removed and replaced with a good one. As we found lot of dust on the adjascent CNC unit, we removed and cleaned it.
After replacing the boards we got 910 Ram Parity error.
We held RESET+DELETE and switched ON the NC power then this alarm dissappeared.
We have a similar machine and we have noted down the parameters and entered them manually into this machine.
We do not find the PLC ladder, when we choose PMC LADDER.
Basically we are not very clear about the step by step procedure to startup this FANUC18-GC cnc. Could anyone please help.
Salamat
Old 05-06-2009, 08:53 AM
memoryman is on a distinguished road
The ladder is not stored in ram, so don't worry about it. If you call me at 519 364 3221 today or tomorrow I can maybe guide you.
Bill
Old 05-06-2009, 09:19 PM
Thanks Mr.Bill, Due to our time zones, Indonesia and Canada, more convinient is posts.
Old 05-07-2009, 06:58 AM
I understand; have been there twice and IPTN is a customer.
We are moving this weekend so I won't be on this site for several days.
Bill
Old 05-07-2009, 08:07 AM
aymancom1 is on a distinguished road
Hi all
please halp me for recover this problem, I have a CNC lathe machine it faced an accident during the transportation caused damage in the outside frame steel I had to take off the following:-
1- The Screen unit (Fanuc oi )
2- The control panel keys unit (Fanuc oi )
3- The z-axis motor cable
And after I had finished the steel treatment I assembled it again,
When I turn on the machine I found two alarm :-
( APC 306 & APC 300 )
I turn off the machine and when I turn on it again the alarm APC 306 disappear ,Now the alarm APC 300 is still appear I Know that is request for reference posithin return to ZRN Z-axis. i want to know how I can treat this matter step by step . (clearly) i already read the manual for this alarm but it is not clear
Old 05-09-2009, 10:19 AM
wujp is on a distinguished road
Originally Posted by aymancom1 View Post
Hi all
You must move Z-axis to the reference position.
Then set ‘PRM.1815’ #4 APZ to 1,there will be alarm"#000 PLEASE TURN OFF POWER".
Restart machine.There would no alarm.
The reference position setting is complete.
wujp
Old 05-10-2009, 10:41 AM
yours_prabhat is on a distinguished road
Salamat
Hi this is Prabhat Mishra from India my mail ID is prabhatmishra@mail.com and cell phone number is +919430737981,+919771570368 please feel free to communicate me in any fanuc electrical and electronics problem while mail me please give all the details of machine including control Alarm message history of problem and If possible please find out the part number you want to know about that and mention .
Regards
Prabhat
Old 05-11-2009, 11:30 PM
fanucman is on a distinguished road
Salamat
The reason u lost memory is because the battery is on the power supply which runs through the back plane to the main board... next time you want to replace the power supply do it quick... aka less than about 2 minutes.. that way you wont loose ur memory.. and make regular sram backups also..
the ladder is not stored in cnc memory is burned onto a chip.. you cant loose it unless you override it or erase it..
Fanuc18 vs. Sinumerik840De Johnmirra General CNC (Mill and Lathe) Control Software (NC) 1 10-07-2005 12:48 AM
