Old 04-30-2009, 09:52 AM
CHANDRU is on a distinguished road
FANUC MEMORY CLEAR & PRECAUTIONS
FRIENDS,
WHAT ARE ALL THE PRECAUTIONS TO BE TAKEN WHILE CLEARING THE MEMORY & RELOADING THE NC,PMC PARAMETERS IN FANUC OM CONTROL.
IS IT NECESSARY TO ENTER THE 900 PARAMETERS BY HAND FIRST.
DO WE HAVE TO DISCONNECT THE I/O CARDS, AXIS CARDS,SPINDLE DRIVE CONNECTIONS ETC AT THE TIME OF RELOADING .
TAHNKS,
CHANDRU
Old 04-30-2009, 10:21 PM
WGoyer is on a distinguished road
FS0M loading
Chandru,
The procedures are different for various versions of the famous Fanuc 0.
The last one I loaded happened to be a Fanuc 0TD, which came from India. There is a label on the top of the logic rack that tells which model it is. If it is an early 0MA, 0TA, 0TB or 0MB, it will have a large mother board. The procedures are different, especially if it is a 0D control. The "D" version has some built in tricks to prevent you from loading certain options. You may need to contact Fanuc to get the procedure for this one. The A, B, and C versions are more straightforward. In these cases, loading the 900's by hand is usually a good place to start.
The brand new 0iT and 0iM are different from the rest.
Which one do you have?
Warren
www.uptimecorp.com
Old 05-12-2009, 12:08 AM
fanucman is on a distinguished road
Originally Posted by CHANDRU View Post
FRIENDS,
TAHNKS,
CHANDRU
why are you clearing memory (910 911 alarms?) make sure you write down the 900 parameters and the diagnostics (i think).. and YES after you do a reset and delete on power up put the 900's in first.. no you dont have to disconnect anything just have estop pushed in for precaution reasons..
try to make a parameter back up or write them all down by hand trust me. it will make life a LOT easier
Old 05-12-2009, 08:29 AM
Al_The_Man's Avatar
With the 0 you can also load the 900's by PC.
They can also be saved this way.
Old 05-12-2009, 12:16 PM
not if you did a reset and delete on power up.. you can punch them out when your done inputting all the parameters.. but you cant just load the 900's via pc initially..
What Fire Precautions Do You Use? diarmaid Polls 27 04-12-2010 10:07 AM
Need Help!- Fanuc 0m-b memory systronic Fanuc 0 12-15-2008 06:47 AM
Fanuc OM-B Memory Fine01 Fanuc 14 10-31-2007 08:36 AM
What fire precautions do you have? diarmaid Polls 0 05-20-2006 02:01 PM
Precautions needed while moving CNC Machines cwww Machine Problems, Solutions , Wireless DNC, serial port 8 03-18-2006 11:28 PM
