Old 04-17-2009, 08:46 AM
starn36 is on a distinguished road
Spindle turn slow(Tsugami - Fanuc 6T)
I recently changed the memory card on my Tsugami Lathe because I got a ROM error. The controller is a Fanuc 6T, version 4
It seem that the cluch of the spindle is not engaged when I start the machine. When I start the spindle (around S2000), the spindle turn at around 50RPM and I'm able to stop it with my hand. The RPM indicater is at 2000RPM. So I think the cluck is not engaged and the spindle turn with a little friction of the clutch. Do you know what cause that?
I have a second problem concerning the tool change. The turret disangaged,turn, re-engaged and then the turret alarm ligth on. I must to restart the controller to close the turret light.
Please help me. The company that sold me the memory card told me that it's not the fault of the card. Maybe a parameter or a setting.
Old 04-19-2009, 01:23 PM
f-bu is on a distinguished road
In my archive there is a ladder from Tsugami/Fanuc6TA and it shows PMC parameter 600.4 for the spindle clutch(if not set, use param. 3001 to set it). Please note, that your machine can be different
Old 04-20-2009, 09:24 AM
Ok, I found the 600.4 in the diagnostic page. It give 0. That's means that the spindle clutch is off like you said.
So, What must I do not active the spindle clutch. In the ladder, I have a reference to OP5.
Do you think that the new memory card cause this problem?
Old 04-21-2009, 01:16 AM
Changing memory card by itself should not make a problem, because these PMC parameters are stored in the bubble memory card.
BUT, the machine I have this backup from, was with PMC-A, and the EPROMs are located on the ROM board you have changed. Check if the same PMC eprom is installed as before.
To set PMC parameters, the best way is to find the original book with the ladder, at the beginning or at the end there must be list of parameters for your particular machine. If PMC parameters need change, you can enter the values trough 3001 for 600, 3002 for 601 etc. (MDI, PRM ENABLE SWITCH=ON, PARAM twice, N3001 input, P<your new value> input)
Old 04-21-2009, 10:35 AM
Wow thanks, it turn
I did'nt know about pressing PARAM twice.
Unfortunately, it's not my only problem. I have trouble concerning the tool changing. The turret disangage, turn, re-engaged and fall in turret alarm (the turret light goes ON). However, the turret lock correctly. I must to restart the controller to use this new turret position.
Can you help me for that. I supposed that it's the same kind of problem.
Old 04-22-2009, 01:04 AM
There is no keep relay for turret rotation, most probably position/in-position switches need adjustment.
Keep relays I have are:
600.0 - bar feeder
600.1 - live center
600.3 - live tool (spindle 2)
600.4 - spindle index/clutch
600.6 - work exchange
Old 04-22-2009, 09:48 AM
Ok I found the problem about the turret
That was the timers setting. There was all set to 0.
Thanks for the ladder learning
Old 01-19-2012, 09:16 AM
marionprecision is on a distinguished road
HI AM NEW TO THIS LOOKING FOR ANYONE THAT CAN HELP ME . TURRET INTEX LAMP COMES ON AFTER EACH INDEX. IS THERE ANY ONE THAT MAY HAVE PARAMETERS FOR THI MACHINE TSUGAMI CNC 2 AXIS WITH FANUC 6T CONTROLI THINK ITS A TB CONTROL
MAYBE MISSING SOME PC- PARAMETERS. MACHINE WAS RUNNING HAS SPINDLE ALARM FIXED THAT PROMBLE NOW THIS
THANK YOU
DENDEN
HELP! Fanuc 3m slow CW Spindle problem SSMrob Fanuc 12 10-04-2011 07:11 AM
Need Help!- Sub-Spindle Ejector for Tsugami NP-20 Thrasher CNC Swiss Screw Machines 3 04-12-2009 08:30 AM
Need Help!- Fanuc / Tsugami 0G-B Controller WayneT Fanuc 2 07-15-2008 05:22 PM
interact 4 spindle drive won't turn on spindle 0041601 Bridgeport and Hardinge Mills 7 06-23-2008 05:51 PM
Slow spindle spin-up on Super X3 StennCU Syil Products 2 04-01-2008 12:26 PM
