Old 04-15-2009, 02:42 AM
padobranac's Avatar
padobranac is on a distinguished road
18i-TA C-axis orientation/referencing/homing/indexing...?
I have ROMI lathe G15SM 2000. y. with driven tools and C axis.
Control is Fanuc 18i-TA.
So, here what I want to do.
First I have to make some operation with milling, than make some turning, and at the end again milling. First milling and second milling must be in relative position, if you know what I mean.
The problem is, when it returns from spindle mode (turning) to the C mode, spindle is not in the same position as it was before spindle mode.
On my VMC, when I enter M19, spindle makes few rotations and comes to one pssition, every time to same place (position for tool changing).
As I know this i called "spindle orientation".
On my Lathe, when I enter M19 (manual says "Main spindle orientation (active C axis)) noting happens, spindle stays in possition without any rotation. I just hear some little more noise from motor, because C axis is active.
Sorry for bad english
Old 04-15-2009, 02:48 AM
jason03 is on a distinguished road
Try G28 H0 this will return C-Axis to home positiion
Old 04-15-2009, 11:51 AM
padobranac's Avatar
Thank you very much, that works
type of motor for A axis - Lathe operation plus indexing? mcArch Plasma, EDM and other similar machine Project Log 0 01-10-2009 07:59 PM
indexing 4th axis 69ss396 Haas Mills 5 12-03-2008 03:06 PM
31i directional 5-axis indexing?? medman Fanuc 0 09-12-2008 12:57 PM
c-axis indexing in g-code Plunker Mazak, Mitsubishi, Mazatrol 3 08-12-2008 06:39 PM
4 axis indexing camtd PTC Pro/Manufacture 1 05-12-2006 07:20 AM
