Do you have a hard copy of the original parameters? The MTB usually puts a hard copy in the power cabinet however these usually disappear over time. If not the 3 options you have are 1.to try and contact the MTB if they are still around they should have a file of all the original parameters. 2.Find someone with the same make/model of your machine and control and get the parameters from them. 3.Step through the parameters 1 at a time using your manual and set each one accordingly. The third is a major PITA.
I can never stress enough that when getting a new or used machine or starting at a new company the first order of business when the machine is first powered on is to backup everything in the control.
In the event that you get parameters you have to enter your option parameters in first through the IPL mode. This will then get you to the CNC were you can set up your communication parameters and then reload all the parameters. Your counters, timers, keeprelys, and data will have to be loaded by hand.
Stevo
LinkBack URL
About LinkBacks
