Old 03-31-2009, 01:18 PM
kf4zht is on a distinguished road
Question Fanuc 11M on Hitachi Seiki VA-45 Locked in tool change
Hi
I was using a Hitachi VA45 machining center in class. It threw a tool during a tool change operation and I hit the E-stop. When we brought the machine back up we attempted the manual procedeures to reset with no luck. I have been working with the lab tech to try and get it working, this is what we have found:
Tool change arm will rotate 180 and spindle unlock works with manual controls
Ladder diagram shows hard overtravel in all directions, if limit switches are pressed manually it will cause alarms
All Axis are locked
Ladder diagram is responding to buttons and switches, machine will not
No error codes on boards
Current Status: tool change arm is down and aligned with spindle/tool pot. Tool changer pot is locked.
Old 03-31-2009, 04:30 PM
chuy's Avatar
chuy is on a distinguished road
Not sure if it will work, but has worked for me in past.,but try placing everything back manually with power off..
Old 03-31-2009, 04:55 PM
We worked on it all afternoon, talked to Faunc who mostly just confirmed what we were thinking.
I think tomorrow we are going to try pushing the arm back up and see where we get unless anyone here has a better suggestion.
Old 04-01-2009, 05:06 PM
I finally figured out how to get it working. Just in case someone needs it in the future:
The machine interlock was turned on, however by traceing the ladder diagram I found the interlock disable would turn off when the Spindle Stop button was held down. While holding the button I was able to zero-return the machine and with the button still held down I could use the tool changer manual controls to finish the tool change operation.
Need Help!- hitachi seiki ht20 fanuc T3 zeeshaniqbal General CNC (Mill and Lathe) Control Software (NC) 0 02-13-2009 01:42 PM
Need Help!- HITACHI SEIKI / Fanuc 11m mn12mike Fanuc 2 12-14-2008 11:06 AM
Problem- Hitachi Seiki Nk40-M with Fanuc 10T hell_pk Fanuc 2 09-10-2008 11:43 PM
Need Help!- Hitachi Seiki NF 20 FANUC 6T - problem with tool changing Xavier M Fanuc 3 08-17-2008 03:55 AM
hitachi Seiki VK45 tool changer stuck Dancy General Metal Working Machines 8 12-26-2007 07:06 AM
