Problem with Fanuc 11M Bubble memory initialization
Results 1 to 13 of 13
Thread: Problem with Fanuc 11M Bubble memory initialization
    Jun 2006
    THAILAND
    Smile Problem with Fanuc 11M Bubble memory initialization
    Hello your help is needed.
    Problem in initializing Bubble memory with Fanuc 11m,
    Due to frequent BUS ERROR and intermittent stop of the machine while running I cleared memory by pressing 7 and 9 button while switch on.
    After this, following screen Displayed.
    ROM TEST: END
    RAM TEST:END
    BUBBLE INITIALISE:END
    BUBBLE TYPE:03
    BUBBLE PREPERATION :ERROR
    0014 E180 0000
    IPL
    1.DUMP MEMORY
    2-
    3.CLEAR FILE
    4.BUBBLE
    5.-
    6END IPL
    I tried to do several time BUBBLE initialize by pressing 4 followed by 2 (for initialize). It ask for Defect Loop Number?
    (I hade selected free mode switch to service mode in Master PCB)
    To check the Defect loop Number in IPL MODE, if I press 4 followed by 3(display defect loop) it gives following display.
    BLOCK#:1A
    READ MAP : TOO MANY DEFECT LOOPS.
    Or
    Some time it display
    NOT READY.
    Due to this, initializing not taking place. Also I am not able to put the option parameters. And other parameters.
    I request is any other method for initialize bubble memory……..? or this could be hardware problem…..?
    Please help to resolve the problem.
    Thanks in advance…
    Dinesh
    Sep 2007
    Mexico
    If you are doing all the procedure as per the book, maybe the bubble memory PC is bad. If you have the chance to get another try to test it that way.
    Greg.
    Mar 2005
    Are we talking about the A87L-0001-xxxx type BMU boards?
    I have had errors like this one before.
    Greg
    Apr 2009
    tou may have to reformat the BMU .Defect loop data is on the BMU itself.
    Call me if you need help.
    Bill Peiman, President
    Tulip Electronics Inc.
    2065 Conservation Road
    Campbellville,On L0P 1B0
    P (905)854-6668
    F (905)854-6669
    Sep 2007
    Mexico
    Yes Greg. That is the Bubble memory. I had the same problem in the past.
    Greg.
    Mar 2005
    Ok, Bill, I'll have to try that next time I encounter this problem.
    I have seen several of these modules on eBay. I would like to upgrade my 11M sometime and would like to know which part numbers to look for and what they are.
    Greg
  7. #7
    Apr 2006
    Call Tulip Electronics
    905-854-6668
    They manufacture replacement boards for the Bubble Memory.
    Much cheaper than Fanuc.
  8. #8
    Nov 2010
    india
    In our Moriseki SL3B machine equipped with FANUC 11 TE Control we have noticed the following screen in the CRT while switching on the machine.
    FS11T9A 220D
    ROM TEST : END
    RAM TEST : END
    BUBBLE INITIALIZE : ERROR
    0002 0000 03FF
    BUBBLE TYPE :04
    BUBBLE PREPARATION : NOT READY
    IN IPL MODE
    1. DUMP MEMORY
    2.
    3.CLEAR FILE
    4.BUBBLE
    5.--
    6. END IPL
    Kindly suggest /send suitable remedial measures / procedure to clear the fault .Kindly note our machine is idle at present.
  9. #9
    Apr 2009
    One of these 3 possibilities:
    1: powers supply voltages; +5V must be at least 4.75V
    2: bad BMU (re-initialise and/or replace); all memory is lost; see maintenance about how to re-initialise
    3: bad motherboard
    #2 is the most likely.
  10. #10
    Jan 2013
    india
    Default Re: Problem with Fanuc 11M Bubble memory initialization
    i have the same problem on fanuc 11m tsugami hmc bubble initialization error how can i solve that error pls help me thank
  11. #11
    Apr 2009
    The bubble board is bad; you will have to replace it and load all data back in. I hope that you have a good backup.
  12. #12
    Mar 2006
    us
    Anytime I see that screen, Ive had to reload all the parameters. Fortunately, I have a good back. I have 2 machines with the 11M. Happens about every other year or so. If you dont know what your doing though, Id pay someone whose qualified. It can effect your options on the machine too, which is another reason to hire someone. It will take less than hour.
  13. #13
    Jan 2013
    india
    thanks how can i reinitialze the bmu board wats the steps can i follow b/s i dont have 11m maintenace manual
