when you go to the Variables screen on a Fanuc 18i the is a place for your Data and a place for a name and a comment does any one now how to input a name or comment there all I get is format error no matter how I try to put any thing in. |
| You can only set names to variables of 500-519 range. The format is as follows: SETVN500[ABCD]---this will put the word ABCD in the 500 variable SETVN501[ABCD]---does the same as above except it sets it to variable 501 I believe on the 18 series control as is most you can only use up to 8 characters. Stevo |
Thanks stevo1 I use Variables #600 and up to store my Z work offset Values because I need more work offsets than the machine has so I call them from the program like this (G55 =#601) #5242=#601 G55 (G56=#602) #5262=#602 G56 and so on It would be nice to lable them on the variable screen the same way |
I don't remember... I also don't have either one of those controls. When I get time later I will check the manual. You could also try and give it a go if you got the control open. Stevo |
| 0i-model B/C does not accept SETVN5xx[]. Names can be specified for pattern data input by macro-A expressions. O9501 ; N1 G65 H92 P066079 Q076084 R032072 I079076 J069032 ; VAR : BOLT HOLE (title) N2 G65 H93 P500 Q084079 R079076 ; #500 TOOL ... 0i-model D, which is more close to 30/31/32, accept SETVN for 500 to 549, eight characters, and you may also use names in statements acc. to the manual: [#POS1]=#100+#101 |
| Homemade Screen Printer/Silk Screen | Sbthomas13 | Machine Created Art | 20 | 02-13-2009 06:35 PM |
| how to set a touch screen on the screen of mach 3 | cob | Mach Mill | 6 | 07-13-2008 05:28 PM |
| Variables 500 to 531 | viorel26 | Fanuc | 0 | 09-30-2007 02:30 AM |
| Local variables | jorgehrr | G-Code Programing | 4 | 02-19-2007 03:03 PM |
| Sinumerik program variables on screen | cosmikdebris | G-Code Programing | 0 | 03-17-2006 07:55 AM |
