Old 03-11-2009, 10:07 PM
eriksalo is on a distinguished road
Fanuc 6MB - Can't set parameters - Help
Hi; I have a 1984 Okada VMC with Fanuc 6MB controlls. The machine has had all the parameters cleared but I have a paper list of the settings. I want to re-enter them by hand. The machine worked fine before it was moved. My problem is I can't write any parameters! Here's what I am doing:
1) Setting the switch on the main board to enable (I get error code 100 on the display when I do this) and select MDI mode.
2) Select a parameter, hit, "P" and key in a value (the p and the value appear on the bottom of the screen)
3) Hit, "input"
4) Nothing happens
What am I doing wrong? One other item is I'm getting a, "not ready" message on the bottom of screen which I assume means the machine is in e-stop mode. Does the, "not ready" message need to be cleared before I can write parameters?
Any help would be appreciated. Thanks; Erik
Old 03-12-2009, 01:34 AM
I received a suggestion that fixed the problem. I needed to hold down the emergency stop button on the controller. When I did that, the parameters programmed just fine.
Thanks to all who looked at this question. Erik
Parameters Fanuc 6M Olsson Fanuc 7 12-26-2009 08:07 AM
Parameters for YAM CK-5, Fanuc 10T gisab General Metalwork Discussion 1 12-07-2009 02:39 AM
fanuc 5t parameters karolg Parametric Programing 1 02-05-2009 10:12 AM
Need Help!- Fanuc 3t parameters lloydy304 Fanuc 1 10-31-2008 07:38 AM
fanuc ot-a parameters iancally Fanuc 0 06-03-2008 10:44 AM
