Old 03-05-2009, 03:57 AM
guhl's Avatar
guhl is on a distinguished road
G02 on 0TB
Hi
My Tsugami NP32 (swiss type screw machine) doesn't wanna perform G02 YZ. Can anybody help me?
regards
Soviet ICs are the largest ICs in the world!!! )))
Old 03-05-2009, 06:44 AM
cogsman1 is on a distinguished road
Did you change the plane? I haven't run that machine in years but a lathe by default is set to "G18" which is "X & Z". If you change to "G19", "Y & Z" it might work.
** Be sure to change back to "G18" when that process is done.
Old 03-05-2009, 07:01 AM
guhl's Avatar
I tried change the plane, but my controller doesn't wanna input G19. And when I input G02, "P/S alarm" appears on the dysplay. I suppose the problem is in option parameters. If you have parameters list still, send it me, please, in order to I compare two lists.
Old 03-05-2009, 08:59 PM
Dan Fritz is on a distinguished road
What is the P/S alarm number? If you didn't have the circular interpolation option turned on, it would be a P/S alarm #10 (illegal G-code). My guess is that it has something to do with the arc center point that you've defined with I or K.
Old 03-06-2009, 11:48 PM
guhl's Avatar
Hi
There was a similar problem on my another machine FA65. I set bit 913.5 and problem has been solved. I tried to make the same trick on NP32, but nothing has come off.
Why???
