Old 02-28-2009, 07:55 AM
hrh hrh is offline
hrh is on a distinguished road
FS-0MA Program comments
FS-0MA does not indicate comments in the program even if the comments exist in the original program generated on the PC.
Maybe Dan Fritz or f-bu can comment if there is a way to make FS-0MA to display comments.
Old 02-28-2009, 11:31 AM
f-bu is on a distinguished road
As far as I remember, 0MA/TA just skip the comments received, they are not save in memory at all. Sorry, have no op. manual for 0 model A just now.
Old 02-28-2009, 02:04 PM
dcoupar's Avatar
Just out of curiosity, are you sure your communications program is not stripping the comments when you send the program to the machine?
Old 02-28-2009, 08:40 PM
Dan Fritz is on a distinguished road
Some communications programs can be set up to strip out comments, but I'm pretty sure that the 0M-A and 0T-A controls strip them out anyway. The 0M-B and 0T-B controls could accept comments. I suppose that Fanuc decided to do this to save memory. Space characters are stripped out on almost all Fanuc models to save memory. The spaces appear on the screen, but they're generated by the display software in the control. When you punch out the programs, the spaces are gone.
Old 03-08-2009, 01:16 PM
hrh hrh is offline
Thanks f-bu and Dan for your replies. The other nasty thing about this control is that the pc parameters cannot be punched out but reading in is working correctly.
Seems that the solution would be to manipulate the CNC software but who is capable?
Old 03-08-2009, 01:34 PM
barbter is on a distinguished road
We had a 1988 fanuc OTA lathe. This stripped out the comments in paranthesis when rs232ing in a program so you got
on the screen where you had say tool comments.
I spoke at length with both GE Fanuc and Fanuc UK who both looked into it and even contacted Japan.
Nothing could be done to allow our control to read them, except 'upgrade to OTB'.
HTH
Program comments in Mazatrol orionstarman Mazak, Mitsubishi, Mazatrol 8 02-20-2008 10:43 AM
fanuc program comments Rich 72 General CNC (Mill and Lathe) Control Software (NC) 3 09-04-2007 07:38 AM
Adding comments in program for Pro NC quadbob PTC Pro/Manufacture 1 04-27-2007 03:54 AM
Program comments in a V2XT? weyland Bridgeport and Hardinge Mills 5 02-09-2007 08:20 PM
Your comments please. MrBean DIY-CNC Router Table Machines 7 09-20-2004 03:47 PM
