WE HAVE IN FANUC OT ALARM 520 OVERTRAVEL +Z WHEN TURN ON . IT REALISES THE USUAL PROCEDURE FOR THIS ALARM BUT I COULD NOT CLEAR IT. LATER IT MODIFIES THE PARAMETER OF SOBRELIMITS BUT CONTINUOUS THE ALARM. IT SEEM THAT THE PROBLEM IS A CARD, BUT I DON`T KNOW WICH. MOTHER BOARD? MEMORY BOARD? THANKS |
| First use MPG move all three axis to center, turn off control, press and hold down P, Q and CAN key turn on control, wait untill control completely on then you can let go the P, Q, CAN Zero return all axis, it should work Ahn Vuong |
| Turn off your machine and then you turn the Z_axis ball screw to go down the spindle till the limit switch is free.Then switch on the machine. If it is still don't work, you need to change the Z_axis parameter. After you turn the ball screw, go to the parameter page and then change the Z_axis limits value. Then restart the machine. It will work. |
roshanlal74@yahoo.co.in |
| I had this same thing hapen to me yesterday to a FANUC OT-C. I'd select mode to reference the axis's. X axis worked but Z would trip and alarm saying Alarm 520 Z+ Over travel. Once reading this thread, I powered down the machine, Powered back on holding on "P" and "CAN" then I tried to reference again and It worked perfectly. Thanks for the info, Chich |
Thanks |
| alarm 510:overtravel X+ | hell_pk | Fanuc | 8 | 12-02-2011 08:55 AM |
| Fanuc 3m Contol, Morton Mill, X overtravel alarm | brgrii | Fanuc | 9 | 10-26-2010 12:24 AM |
| Y hard overtravel alarm | Chappyd | Hyundai Kia machine | 2 | 02-05-2009 07:25 AM |
| Bridgeport VMC 760/22DX Soft Overtravel Alarm | nlh | Bridgeport and Hardinge Mills | 0 | 04-30-2008 07:21 AM |
| Keep getting z axis overtravel alarm 146 | dragon864 | Haas Mills | 3 | 07-20-2007 06:13 PM |
