Old 02-24-2009, 09:49 PM
hongjianming is on a distinguished road
parameter
hello everyone
our company bought old machine. the machine had not been run for long time, no battery, lost all parameter, i got cnc parameter and pmc parameter only, but i don't know how to put parameter into machine by hand. another question, the machine can be run, do need additional parameter?
thank you
Old 02-24-2009, 09:52 PM
the machine system is fanuc 16tb
Old 02-24-2009, 10:03 PM
hawkburger is on a distinguished road
You say that it runs, why worry about a bunch of un-needed parameters then?
Old 02-25-2009, 08:16 PM
sorry,my english is poor.
the machine stoped, no battery, lost parameter.
i got cnc and pmc parameter only, but i don't know how to put parameter into machine by hand.
another question, For the machine can the normal work, but also needs any parameter?
Old 03-01-2009, 08:38 AM
BKCOM is on a distinguished road
Hi.
PMC program did not lost.
You should take a PCMCIA card. Copy parameter and change the name to "CNCPARA.DAT"
Put Card into PCMCIA slot on CPU 16TB and read all parameter in to memory.
Goodluck
Old 03-02-2009, 08:44 AM
wujp is on a distinguished road
Mr hongjianming
hello
at the first ,backup parameter have two types. SRAM or CNCPARA,DAT
just like you say "For the machine can the normal work, but also needs any parameter? "
it means this machine work normaly ,
it's no alarm ,
Machine can cut part ,part also is eligible .
It that your means ?
Like that machine is OK,parameter is looks like nomaly.
I can hlep you put the backup parameter into NC in Chinese .
mail to qq537300@163.com
Old 05-25-2011, 12:50 AM
Karsue is on a distinguished road
Hi First thing that you should do to enter the parameter with Fanuc control is to change the value of PWE (Parameter Write Enable) from 0 to 1 as follow:
1- Select MDI mode and push Emergency Stop.
2- Push Setting softkey as many times till you get the page of setting (Handy).
3- bring your curser to Parameter Write or PWE then input 1, now you can enter all your parameter by hand or any device to your control and as soon as you change the value of PWE from 0 to 1 you will recieve P/S alarm 100, it is normal.
4- After finishine Para entry, you have to change PWE to 0 then press reset and turn off the machine for 30 sec.
I hope these information were what you were looking for.
Karsue
Old 05-25-2011, 05:20 AM
tc429's Avatar
tc429 is on a distinguished road
might be a couple years late
i just replied to one over a year old too, always forget to check the dates...
MV-JR parameter?? machine1956 Mori Mills 4 07-14-2010 11:33 PM
ymc 60A parameter saptyawan CNCzone Club House 0 06-16-2008 11:45 PM
parameter davek Fanuc 6 11-08-2007 07:45 AM
parameter 64 swartling Haas Mills 0 02-20-2007 04:57 PM
