I just got a Yang lathe cnc with a FANUC O-TD interface and Im trying to transfer code from my labtop to the FANUC via Predator CNC editor. I am able to transfer code from the FANUC to my CNC editor but when I transfer data from the CNC editor to the FANUC nothing happens on the FANUC side but the CNC editor says that 100% of the data has been transfered. Any suggestions on what is going on? |
| If the LSK symbol stays on while the Predator system is sending data, it may be that the control does not have the ISO code option installed. Fanuc considers EIA code to be "standard" and ISO or ASCII code is an option (really!). Try setting the Predator system to transmit EIA RS244 tape code and see what happens. It may be that Predator is able to receive OK because it has automatic code recognition. If the Fanuc also has auto code recognition, it would be reading OK. See if EIA works. Another possibility is that the Predator system is not sending a LF (Line-feed) character at the end of each block. Be sure that it's set up to send LF as an EOB character. |
| you need config your cnc an pc sent you a link where it says how to do http://www.kfasllc.com/rs232_0.htm you can help me i need parameter sml20 fanuc otd 900 to 939 thanks you |
| Tags |
| o-td help |
| Need Help!- Portable CNC data transfer Box | xyzer | Machine Problems, Solutions , Wireless DNC, serial port | 1 | 07-21-2011 12:53 AM |
| Newbie- Problem with Data flow between Fanuc 6M and DNC software | Saluce | Fanuc | 1 | 08-27-2008 07:20 PM |
| Recommend data transfer software for Fanuc Series 21i-TB | dazz_ | Fanuc | 13 | 05-02-2008 12:47 PM |
| Problem in trasmission of data to Fanuc 6m-b | giorgis | Fanuc | 7 | 12-20-2007 06:16 PM |
| Fanuc 9M data transfer problem | YOO | Fanuc | 1 | 01-18-2007 08:26 AM |
