Old 02-19-2009, 11:36 PM
sinha_nsit is on a distinguished road
macro format error while using boolean functions
The book by Peter Smid on Fanuc Macro uses statements like
#5 = [#1 EQ #2] on page 125.
This,however, gives MACRO FORMAT ERROR on my 0i Mate TC.
Is there a parameter which can be used for allowing such statements (assigning 1 for TRUE and 0 for FALSE)? Or, is Peter Smid wrong?
Old 02-20-2009, 04:33 AM
chetan is on a distinguished road
Cool
Hi sinha
I dont know about peter smid. i think you should use g65 command which is actual macro command in fanuc. If you need it i can help you in that.
Regards
Old 02-20-2009, 08:14 AM
stevo1 is on a distinguished road
Sinha,
I have never seen a macro statement like that before. I have not read Peter’s book so I don’t know what he is trying to refer to in that statement. When using the EQ, LE, GE, statements this is usually to go to certain area’s in the program or to set a certain number.
Example
IF[#1EQ#2]GOTO100
G0G28Z0
N100M30
In this statement if variable #1 was equal to variable #2 then the program would jump to N100 line and end the program with the M30. However if variable #1 was NOT equal to #2 then the program would go to the next line of G0G28Z0 then end the program with M30.
Or you can use the format of IF[#1EQ#2]TH#5=10. This will set #5=10 if #1 is the same as #2. If it is not then nothing will change with #5.
#5=[#1EQ#2] is not a proper format of a macro for a Fanuc control that is why you are getting the alarm. The only thing that I can think is maybe the EQ is suppose to be a +. Then #5 would be set to the sum of #1+#2.
Chetan,
The G65 is a macro “call” not a function that you turn on and off to use the variables. The G65 is a way of passing data to your local variables. For example a few of the local variable assignment is A=#1, B=#2, C=#3, D=#7. So if you wanted to write a statement using your macro call you would format it like this.
O0001(main program)
G65P8000A5B10D4C35
M30
What this code will do is call program 8000 just like a sub program using M98 except #1 would equal 5, #2=10, #3=35, #7=4. You then write your 8000 program using these variables.
O8000
G0G90X#1Y#2Z#7
G1Z-#3
G0Z#7
M99
Stevo
Old 02-20-2009, 08:36 AM
Smid believes that TRUE is equivalent to decimal value 1, and FALSE is equivalent to decimal 0. But actually it is not so, unless there is a parameter for such an interpretation.
Old 02-20-2009, 09:05 AM
I have no idea what that means . Can you explain what that means? So when something is false it is =1. and if something is true it is =0. I don't follow you. I do extensive macros and I have never even seen that in the Pascal format. Am I missing something or misunderstanding what your saying?
Stevo
Old 02-20-2009, 10:35 AM
viorel26's Avatar
viorel26 is on a distinguished road
sinha_nsit post Peter’s book page 125
#5 = [#1 EQ #2] on fanuc is a MACRO FORMAT ERROR
see stevo1 example for corect format
stevo1
other use of G65 on Fanuc with Macro A
G65 H81 P1000 Q#101 R#102 ( IF[#101EQ#102]GOTO1000 )
Old 02-21-2009, 12:17 AM
Stevo
Ok, I have copied exactly what is given in the book:
Boolean and Binary Examples
As an exercise, evaluate the following macro data entries. The first group is the given data, the second group is the evaluated data, and the final third group is the compared data.
Given data:
#1 = 100.0 Stored value is 100.0
#2 = #0 No data - variable is VACANT
#3 = 100.0 Stored value is 100.0
#4 = 150.0 Stored value is 150.0
Evaluated data:
#5 = [#1 EQ #2] Returns 0 = FALSE
#6 = [#2 EQ #3] Returns 0 = FALSE
#7 = [#2 EQ #0] Returns 1 = TRUE
#8 = [#1 EQ #3] Returns 1 = TRUE
#9 = [#4 GT #3] Returns 1 = TRUE
Compared data
#10 = [[#1 EQ #3] AND [#2 EQ #0]] TRUE, because both values are true
etc.
My observations:
What he writes on the right-hand side of = is OK, but TRUE or FALSE values cannot be assigned to variables which can only store arithmetic values. Smid believes that when TRUE is assigned to a variable, the variable stores 1. Similarly, assigning FALSE to a variable makes the variable store 0. At least on my machine, with the current parameter setting, this gives MACRO FORMAT ERROR (alarm no 114). I could not find any parameter in the parameter manual for such an interpretation of TRUE and FALSE. TRUE and FALSE are boolean values, and cannot be mixed up with arithmetic values.
Old 02-21-2009, 01:41 AM
Sinha,
Example
IF[#1EQ#2]GOTO100
G0G28Z0
N100M30
Chetan,
O0001(main program)
G65P8000A5B10D4C35
M30
O8000
G0G90X#1Y#2Z#7
G1Z-#3
G0Z#7
M99
Stevo
Hi
You are saying that is different.There are two types of macro body A type and Btype . what i mean to say is just see below
N0....start of the program
G65 H02 P#100 Q#100 R1 ( this balock will add 1 input in the variable #100)
G65 H82 P0 Q#100 R10 ( this block will see that variable #100 is equal to 10 or not
if it is not equal then it will go to N0
if it is equal then it will go to next block)
G65 H01 P#100 Q0 ( in this variable #100 is made equal to zero)
M30 (end of the program)
The above sample i had used for running the program 10 times i.e. for 10 jobs.
H02 is for addition
H01 is for equal
H82 is for conditional divergence.
This works 100%
Old 02-23-2009, 07:06 AM
You are correct. Are you using macro A or B? I don't use macroA so I can no explain or answer for any of the different funcitons that this may have compared to macroB. If I wanted to set a value to #10 if #1 and #2 were the same I would use IF[#1EQ#2]THEN#10=1. Maybe it is done how the book explains because I don't think macroA supports the IF or GOTO statments.
Chetan,
I am not saying that you are incorrect with your programming that you gave in your last post. I would assume that you are using macroA? However with your post you made here you made it sound like you need to activate G65 in order to use the line of code Sinha_nist originally posted "#5 = [#1 EQ #2] page125". You can use variables or calculation lines anytime in a main or sub program not needing to use G65 at all.
Stevo
Old 02-23-2009, 09:32 PM
My machine has Macro B.
The book also claims to have been written for "Fanuc Custom Macro B users".
Are you people aware of any other book on Macro B, which describes it in detail, not just as a 10-page Chapter in a conventional programming book?
I have heard about Mike Lynch's book, but it is too expensive, above $90. Mike Lynch is a big name, but I have no idea about his book. Any comment from you? Any other good book?
  #11   Ban this user!
Old 02-24-2009, 12:47 AM
Hi
I think you you should use common variables instead of local variables. I dont know much about this, it is just suggestion. Infact i need to know is there any diff bet them.
  #12   Ban this user!
Old 02-24-2009, 12:56 AM
If you have used some programming language such as Pascal, it would be easy to understand.
Local variables are same as local variables of a Fortran subroutine (called Procedure in Pascal).
Common variables are global variables which can be use everywhere with the same meaning.
Boolean Operation with a Mesh chaddcurtis Rhino 3D 10 02-22-2011 02:08 PM
Macro Syntex Error??? jamesweed Fanuc 5 02-20-2009 01:02 AM
Need Help!- V22 Boolean Subtract TZ250 BobCad-Cam 12 12-03-2008 01:11 AM
Boolean camtd SolidEdge 0 09-21-2008 06:31 PM
Boolean Feature svenakela SolidEdge 2 08-27-2007 09:18 PM
