Old 02-16-2009, 03:50 PM
meadowtech is on a distinguished road
OM-D decimal place limits
My software is putting out cordinates with 5 place decimals, will the control handle this?
Old 02-16-2009, 08:44 PM
dcoupar's Avatar
I believe it will... seem to remember an old post doing that, and it still ran. What software are you using? Is it not configurable?
Old 02-17-2009, 09:03 PM
GPena is on a distinguished road
I think it will take 4 decimals in inch and 3 in metric system.
Greg.
Old 02-18-2009, 04:02 PM
I changed the software to put out 4 places and it seemed to work fine, but then the machine froze about half way through a 3D drip feed program. No alarms and the control was not responsive, I couldn't switch screens or get any response unless I hit reset. I'm using Bobcad 17
Old 02-20-2009, 01:36 AM
sinha_nsit is on a distinguished road
The number of decimal digits is an issue only in direct assignment. Fanuc Macro B accepts only 8 digits. For example
#1 = 1.23456789 would alarm out (TOO MANY DIGITS)
but
#1 = 1.2345678 would be OK.
If the least input increment is, say, 0.001, rounding to three places after decimal would be automatically done. For example
G21;
G91 G01 X#1 F_;
would cause a movement of 1.235 mm.
When the assigned value is through a calculation (the result of which has more than 8 digits), there is nothing to worry. Rounding to 8 digits would be done automatically:
#1 = 2;
#2 = 3;
#3 = #1 / #2
This would store a value of 0.6666667 in #3.
Note that #3 - 0.6666667 would not return exactly zero, because an error of 0.00000001 is typically associated with all macro calculations.
Forcing a decimal point from a pci inflateable EdgeCam 0 10-28-2008 08:58 AM
Need Help!- putting in decimal places. G00 G-Code Programing 4 08-27-2008 02:27 PM
Mastercam X, force 4 decimal place output critz General CNC (Mill and Lathe) Control Software (NC) 2 05-19-2008 11:59 PM
decimal point stevieboy Mastercam 9 01-10-2007 05:42 AM
