A value, arising out of a macro calculation, lying between -10exp-29 and +10exp-29 (but not equal to 0) is not permitted, generating an alarm condition (CALCULATED DATA OVERFLOW). However, a programmer may desire that the control should ignore this "error”, and treat any value in this range as 0. This might be possible through a parameter setting. Can you please let me know this parameter. 6004#1 is for a different purpose (only for SIN, COS and TAN), and does not work in this case. Thanks. |
| What is the code that you are getting the alarm from? I don't know of a parameter that change adjust that. What i do to not allow the over calculation or leading 0's to calculate to far is use the ROUND function. Even if you need a accurate number say 5 places past decimal you can use the round to make sure you get .00001 ect. Stevo |
| My question is purely of academic interest, which is not likely to occur anytime. Consider the following: #1 = .00000001 #2 = #1 * #1 * #1 * #1 This would generate an alarm because #2 is less than 10 exp(-29). However, this is a case of mathematical underflow, and can be treated as 0, for further calculations. But, the control does not do that. Possibly, there might be some parameter for this to happen. |
| Handling large parts | cdlenterprises | General Metalwork Discussion | 7 | 06-14-2009 11:13 PM |
| Oil And Coolant Handling Simplified | Geof | Haas Mills | 2 | 03-16-2007 08:11 AM |
| CNC control handling table | chris blanchard | Mechanical Calculations/Engineering Design | 1 | 08-02-2006 04:45 PM |
| better way of handling classifieds | daedalus | Suggestions for the CNCzone.com site. | 6 | 04-13-2006 07:27 AM |
| Handling rendered images | HuFlungDung | OneCNC | 4 | 06-21-2003 10:22 AM |
