Old 02-08-2009, 05:38 PM
meadowtech is on a distinguished road
fanuc OM-D spindle orientation parameter?
Spindle is locked in the wrong position at tool change. is there a parameter for indexing spindle to correct position?
Old 02-08-2009, 08:58 PM
avtechmachine is on a distinguished road
try parameter 6577, increase or decrease the value it should work.
if machine run into wrong position again, you should check the timing belt or the spindle belt
Ahn Vuong
Old 02-09-2009, 11:15 AM
samu's Avatar
samu is on a distinguished road
if it doesn't work, try prm#6531 (Position coder method orientation stop position)
#6577 is Orientation stop position shift amount
I think both work
FANUC-6M SPINDLE ORIENTATION CHANDRU Fanuc 5 04-18-2009 01:05 PM
Horizontal mill index table orientation parameter 68 SS Fanuc 0 10-27-2008 09:39 PM
Manual for Fanuc Spindle Orientation board MetLHead Fanuc 1 02-14-2008 02:23 PM
Spindle orientation StampCraft Haas Mills 5 11-10-2007 05:31 PM
How to setting fanuc serial spindle parameter? ning Fanuc 1 10-30-2005 02:38 PM
