Old 02-08-2009, 01:30 AM
teamjnz is on a distinguished road
Question Feed rate override and Dry run not working
Hello Friends,
Today was the first time I have been able to set up and run my machine. I have been working on getting it running for a few months. It was pretty cool making a part in my garage.
Anyway the machine is a 1984 Kitamura MyCenter1 with the Fanuc 3M controller. When setting up I noticed I wasn't able to control the feed rate when in JOG mode while cutting jaws. Normally when jogging the feed rate can be controlled with the feed rate override, faster or slower.
I also tried using the feed rate override while running a program and it didn't slowdown or speed up when turning the knob. This prompted me to try the DRY RUN switch and it didn't work either. I figure they both should be working or Fanuc wouldn't have put them there. I am still learning this older control. Is there a trick or something I need to do to enable them?
_____________
teamjnz
Old 02-08-2009, 04:32 AM
Dan Fritz is on a distinguished road
Look for a button or toggle switch called "OVC". Many machines don't have this switch, but yours might. OVC means "Override Cancel," and it inhibits feedrate override and Dry Run.
You might also have a problem behind the operators panel. If the +24v supply to the panel is lost, then lots of buttons and switches will stop working. Most likely though, if your Jog buttons and other operator panel functions are working, your panel is OK.
Old 02-08-2009, 11:57 PM
Hello Dan,
I have read many of your post replies. You seem to really know your stuff. Anyway I don't see an OVC switch. Many buttons do work, both +- jog buttons, the carousel and CW, CCW spindle buttons. The single block and Op stop toggles work too.
Since these buttons work would this mean the 24 volt supply works? Another question is could there be two 24 volt supplies to the panel and one of them went bad?
_____________
teamjnz
Old 02-09-2009, 08:40 AM
stevo1 is on a distinguished road
I don’t know much about the 3 series controls but on the series I work with there are parameter settings to enable/disable these overrides. Do you have the parameter book for the control? I am not sure if they will be parameter settings for you but I use the system variables. On my controls it is #3004=0 to enable feed override and #3004=2 to lock the override.
Stevo
Old 02-10-2009, 12:16 AM
Stevo
Hi Stevo,
I looked in my parameter book and my parameters don't go that high. I did find a M code that may have something to these button not working.
M48 = Feed Override Cancel
M49 = Feed Override Set
I am going to try the M49 tomorrow. I will post my findings
_____________
teamjnz
Old 02-10-2009, 07:03 AM
Let us know if that works.
As to the #3004 it will not be listed in your parameter book. At least any books that I have seen. These are common Fanuc system variables. However I don't know if they are for your 3 series control. You will also not have your input/output variables listed in your book either. These are typically set by the MTB and they make there own list of some sort that will got with the machine. However these are usually the first books lost.
Stevo
Old 02-10-2009, 04:53 PM
The 3 series control doesn't have any parameters in that range. It may have parameters from 1000 to 1027 and 2000 to 2127, but those are for pitch error compensation (if you have the option). If the M48/M49 is listed as OverRide Cancel, then it is probably included in the ladder logic that M48 turns on the OVC cancel signal that I mentioned earlier. Instead of a panel switch, H.S. may have just used the M-codes instead. That makes sense.
Old 02-10-2009, 10:53 PM
Well M49 did not work it just froze on the M-code. Any other ideas? I really need to be able to use feed override.
As for the parameters in the machine they are number like this:
1 thru 239
300-639
996-1115
The software version is D65-11. 3M Model C -83.11.18-
_____________
teamjnz
Old 02-12-2009, 02:15 AM
f-bu is on a distinguished road
I could not remember to have OVC on 3M-C, I used to do it in the ladder. See attached address table, could be useful.
Sorry, the address is 106.4, OVRC
Old 02-12-2009, 09:08 AM
cncdiag is on a distinguished road
Dry run check diagnostic 20 bit 3
Feedrate Override diagnostic 0 bit5, 2 bit 0, 2 bit 3, 2 bit 6
  #11   Ban this user!
Old 02-13-2009, 02:23 PM
Hi cncdiag,
Please bear with me. You are asking me to look at DNG#20 and look at the 3rd number to the left, bit 3? There are 8 numbers in DNG#20...
I guess I don't understand. Sorry. I have been making parts for over 20 years but never worked on the machines.
I spoke to the last owner about the override not working. He said 3 or 4 years ago he had a board fixed, which one I don't know, and the parameters reloaded. That is when the feed rate override stopped working. They didn't use the machine very much so he never bothered fixing it.
Any direction to point to? I have all of the books including the electronic schematics. I found the feed rate override in the ladder logic, but I don't understand that either.
Thanks for helping.
_____________
teamjnz
  #12   Ban this user!
Old 02-13-2009, 02:37 PM
Bits run from right to left (76543210). So as you see if they are all 0's except for bit 3 it would look like this 00001000.
Try doing a search in your diagnostic bits. I believe what you need to search for is X020.00. So if you do a search for that "X020.00" or just X20 this i think is were you are suggeted to look. I am not sure for your control.
Stevo
feed rate override not working or i am dumb and its right there ataxy Mach Software (ArtSoft software) 2 11-28-2008 05:20 PM
Lock out feed rate override Daves 41 Haas Mills 21 04-21-2008 05:14 PM
Need Help!- Feed rate Ovverride also Increases rapid rate. Korellibopper Machines running Mach Software 1 01-30-2008 05:37 PM
Mach 3 & Feed Rate Override aus-newb Mach Lathe 1 11-21-2005 06:56 PM
Feed Override SCOJEN DIY-CNC Router Table Machines 0 01-24-2005 12:56 PM
