Hi guys. Anyone that knows what is the difference between the encoders model A860-0304-T012 and A860-0304-T112, I have the descrition and both seems to be the same, phisically they are equal also, I want to replace one for the other... Thank you for your advice. Greg. |
| I just have a listing for the T112 which is 2500p/rev incremental. If you have the motor the T012 came off the encoder can be identified by the yy, in e.g. A06B-0314-Bxyy. Al.
| I have a listing for quite a few encoders, but the T012 is off the encoder, the part number on the motor also indicates the encoder, the example I gave was for an AC servo motor A06B-0314-Bxyy. The x & yy indicates the end cap and encoder used in the motor. Al.
| Thank you Al, doing some research I found what you explained in your first reply. T112 is incremental and T012 is absolute; I do have a T012 bad and we will replace it with a T112 in good shape, I think this will work. I'll let you know. Thank you for your help. Greg. |
| Need Help!- Difference between 2D NC and 2.5D NC | Pols | General CAM Discussion | 1 | 10-14-2008 07:30 AM |
| Difference between T32-2 and T32-B | mbpp | Mazak, Mitsubishi, Mazatrol | 3 | 09-05-2008 02:52 PM |
| What's the difference? | saturnnights | Knee Vertical Mills | 10 | 05-04-2006 10:31 AM |
| What is the difference? | Hack | General CNC (Mill and Lathe) Control Software (NC) | 5 | 10-09-2005 09:46 AM |
| How to tell if my motor is Pulse encoder or quadrature encoder? | Darc | Servo Motors and Drives | 0 | 07-22-2005 03:51 AM |
