Old 02-04-2009, 06:49 AM
Dustin L is on a distinguished road
Possible spike in the 24 volt system
I am having a problem with my Amada Coma Punch Press running a Fanuc 6M controller. It seems that the 24 volt system is spiking and causing the controller to reset. I believe Diagnosis 804 for my machine is the voltage and it usually runs at around 2400 to 2500 but right before the controller kicks out the number jumps up to 3600 or so. If anyone knows anymore about what might be going on here I could always post more info.
Thank You in advance
Dustin L
Old 02-04-2009, 07:00 AM
Rich 72 is on a distinguished road
Is this happening while the press is moving?
If it is I'd start by checking to see if there are any wires or components on the ram or if there is something being rubbed by the ram while it is moving
Old 02-04-2009, 07:29 AM
yes it happens when the axis are moving, I'm writing a program to run one axis at a time to see if I can narrow down my search. Would a short in the wiring cause what appears to be a voltage spike though?
Need Help!- Converting DSP controller system to Mach based system. Marwell Machines running Mach Software 0 12-19-2008 05:00 PM
Need Help!- Kitamura Mycenter 1 480 volt to 240 volt conversion? mjrockwellus General Metal Working Machines 2 10-21-2008 11:14 AM
Fanuc OM Height of riversal Spike F.Sharifi Fanuc 2 05-30-2007 02:00 PM
Encoder failure caused by Interference spike Al_The_Man General Electronics Discussion 6 08-19-2004 11:26 PM
What is Volt-Amp? creative_mind General Electronics Discussion 4 02-11-2004 03:59 AM
