I have a Warner Swasey WSU 12 w/ fanuc 10tf control. Everything was going good on it untill out of the blue an alarm "PS187 FEED ZERO(COMMAND)" comes up. IT alarms when the turret starts to index. It has something to do with the offset call with the turret. I can MDI T0100, T0200 etc and it will index fine with no alarm. When I add the offset call T0101, T0202 etc it will alarm. This just started suddenly and was running parts fine before. Any help would be appreciated. TIA |
| Beege is right we need more code to look at. However the alarm that you are getting is typically when you program a linear move but you have not specified a feedrate. Is it possible that the control is looking ahead a few lines past your T0101 and seeing a linear move with no F command and that is where the alarm is generating? Stevo |
| Here is the code below. This is the first job I have run on this machine so I am sure it needs some editing. But like I said before it was working fine before and all of the sudden I get the alarm msg. I did make an offset before this happened but I don't see anything wrong in the offset tables. Thanks. % O2486 N0100G70 N0101G90G92S800 N0110G95T0101M03 N0120G96S400M08 N0121G00Z.25 N0130G00X1.1000Z.0933 N0140G01Z-.0067F.0120 N0150Z-7.4900F.0160 N0160X1.2500 N0170X1.2600 N0180G00Z.0933 N0190X.9500 N0200G01Z-.0067F.0120 N0210Z-7.4900F.0160 N0220X1.1100 N0230G00Z.0933 N0240X.8000 N0250G01Z-.0067F.0120 N0260Z-.1323F.0160 N0270G03X.8160Z-.1719I-.0409K-.0395 N0280G01Z-3.0178 N0290G03X.8240Z-3.0469I-.0489K-.0291 N0300G01Z-7.4900 N0310X.9600 N0320G00Z.0933 N0330X.6743 N0340G01Z-.0067F.0120 N0350X.7993Z-.1317F.0160 N0360G03X.8100Z-.1464I-.0402K-.0402 N0370G00X1.3848 N0380Z.1519 N0390M09 N0400G00X4.0Z1.0 N0410T0100 N0420M01 N0440G00T0202M03 N0450G96S400M08 N0451G00Z.2 N0460G00X.5718Z.0908 N0470G01X.6718Z-.0091F.0100 N0480X.7968Z-.1341F.0120 N0490G03X.8060Z-.1563I-.0221K-.0221 N0500G01Z-3.0104 N0510G03X.8140Z-3.0313I-.0233K-.0209 N0520G01Z-7.5000 N0530X1.2500 N0540X1.3500 N0550G00X1.3848 N0560Z.1092 N0570M09 N0580G00X4.0Z1.0 N0590T0200 N0600M01 N0620G00T0808M03 N0630G97S400M08 N0631G00Z.750 N0640G00X.9060Z.5776 N0650X.7919 N0660G33Z-3.0000E.181818 N0670G00X.9060 N0680Z.5753 N0690X.7793 N0700G33Z-3.0000E.181818 N0710G00X.9060 N0720Z.5734 N0730X.7682 N0740G33Z-3.0000E.181818 N0750G00X.9060 N0760Z.5717 N0770X.7583 N0780G33Z-3.0000E.181818 N0790G00X.9060 N0800Z.5701 N0810X.7497 N0820G33Z-3.0000E.181818 N0830G00X.9060 N0840Z.5688 N0850X.7421 N0860G33Z-3.0000E.181818 N0870G00X.9060 N0880Z.5676 N0890X.7355 N0900G33Z-3.0000E.181818 N0910G00X.9060 N0920Z.5666 N0930X.7297 N0940G33Z-3.0000E.181818 N0950G00X.9060 N0960Z.5657 N0970X.7247 N0980G33Z-3.0000E.181818 N0990G00X.9060 N1000Z.5649 N1010X.7203 N1020G33Z-3.0000E.181818 N1030G00X.9060 N1040Z.5643 N1050X.7165 N1060G33Z-3.0000E.181818 N1070G00X.9060 N1080Z.5637 N1090X.7133 N1100G33Z-3.0000E.181818 N1110G00X.9060 N1120Z.5632 N1130X.7104 N1140G33Z-3.0000E.181818 N1150G00X.9060 N1160Z.5628 N1170X.7080 N1180G33Z-3.0000E.181818 N1190G00X.9060 N1200Z.5624 N1210X.7060 N1220G33Z-3.0000E.181818 N1230G00X.9060 N1240X1.5984 N1250Z.1377 N1260M09 N1270G00X4.Z4. N1280T0800 N1290M30 % |
| Fanuc 10TF Questions | metx | Fanuc | 6 | 11-09-2010 08:08 PM |
| Need Help!- Hitachi HT-25S Fanuc 10tf | mbcarl | General CNC (Mill and Lathe) Control Software (NC) | 1 | 01-01-2009 08:05 PM |
| fanuc 10tf | morris | Fanuc | 0 | 04-17-2008 10:20 AM |
| Need Help!- Fanuc 10TF PMC Parameters | leturc | Fanuc | 3 | 03-17-2008 10:42 PM |
| Fanuc 10tf Alarm | L. Sakthivel | Fanuc | 1 | 05-29-2007 10:49 PM |
