I can do the cnc parameters backup of FANUC 15MB system with DNC software. but i can't punch the PMC data with DNC software.i wondered is it possible to punch the PMC data with DNC software.if so,which parameters should be set and how to set? any one any ideas will be great appreciated. |
| You have to set parameter 8000 bit 0(PWE) to 1. Then go to the PMC/CNC and set your K17 keep relay bit 1 to 1. Now you are ready to output PMC data. Press softkeys: I/O and select the FDCAS as the I/O device. Press the PCPRM softkey to select the PMC data as the type Press the WRITE softkey to select the data output. I don’t remember if you can type a file name before pressing the EXEC key. If so type the file name you want it to be then press teh EXEC key. Channel numbers 1=JD5A, Channel 2=JD5B. If you want to change the baudrate you have to select the SPEED on the I/O screen. Good luck, Stevo |
| Your welcome for the help. How did the data come out? Did it come out in S-form or CNC-form? The DNC software should not care how the data is open or saved. You should have no problems sending it back to the machine if you need to. Just as long as it is not garbled (distorted). The S-form should look something like this starting with a S at the beginning of each line. S22420000000020000000000005AA S22420002000060000FF230000DAE The CNC-form like this. N60000 P0 N60002 P0 N60004 P0 Stevo |
| i am absent for a few days due to some special reason.the data of the pmc's parameter is "N@0@0@ @0@ NN@0@12 @0@ N@0@14 @0@ N@0@1@ @0@" the data of the pmc's laddar is "&ER@:S@0@0@0@0@F@@ S2242@0@0@0@0@20@0@0@0@0@0@5@AA@0@0@0@0@0@0@00@0@0@0@0@0@0@00@0@0@0@0@0@0@00@0@B@@S@242@00@2@0@0@0@0@FF2@0@0@E@D@FFFF0@0@0@0@0@2C@0@0@B@0@0@0@1C@B@0@0@28@0@0@0@7@S@242@0@4@FFB@0@0@6@5@0@0@00@0@0@0@0@0@0@00@28@F@0@0@0@40@0@D@0@0@0@3@E34@0@0@B@" i am not sure if it is useful.i punched the data out with DNC software.i am not sure which code it is.i don't know how to change the setting of the code. many thanks. jeff.liu |
| hello everybody: finally i got the PMC's data out with correct setting. last time i made the wrong setting of parity checking with "none".it should be "even" with FANUC 15m. and now everything is OK. the data of PMC' parameter is N60000 P0 N60002 P0 N60004 P0 the data of the PMC's ladder is S22420000000020000000000005AA500000000000000000000000000000005000000000000B5 S22420002000060000FF2B0000E5DCFFFF00000000002C0000B60400001C5B00002800000027 thank's a lot for everyone's great help. |
#10
hi, i realise this has been posted here a while now but im quite new to fanucs i can find my way round them and sort problems out within the pmc tables and ladders (the fault finding is not the problem). but now i have to back up the machines as one has recently lost all data when sent away for repair. can this same procedure be used for a dnc link to comunicate with a 10t |
| Problem- memory card of FANUC 15MB | jeff.liu | Fanuc | 12 | 05-07-2011 07:37 PM |
| Need Help!- Fanuc 15MB and Rotary Axis | garysparks | Fanuc | 4 | 01-30-2009 07:15 AM |
| Problem- Pallete table & the 5th Axis isn't working in Fanuc 15Mb | nessei | Fanuc | 1 | 02-04-2008 11:46 AM |
| Fanuc 15T Backup Information | Swarf Bin | Fanuc | 5 | 03-07-2007 11:43 AM |
