I finally got my W&S WSU 12 running on a job and had the surprise of my life right at the start. It was in a rough turning pass and I needed to stop it so I pushed the feed Hold button. The feed stopped, but as soon as I let go of the button it started again. Can somebody tell me if there is a parameter that will make the machine stop motion after you release the button and resume again after either you push the feed hold button again or the cycle start button? This is a Fanuc 10TF control. TIA |
| That is unusual, normally the start button needs to be pushed. This is normally set up in the ladder, look in the ladder string for the FH function and it should confirm how it is set up. Al.
| Feed Hold | HelicopterJohn | Haas Mills | 10 | 04-24-2008 09:57 PM |
| Feed hold problem | kirby | Fanuc | 11 | 07-13-2007 08:33 AM |
| Stop or Feed Hold Key | rweatherly | Mach Mill | 13 | 11-12-2006 01:28 PM |
| Door Feed Hold | 1ctoolfool | Haas Mills | 2 | 09-12-2006 09:45 AM |
| What should Feed Hold actually be?? | REVCAM_Bob | Servo Motors and Drives | 4 | 01-22-2006 12:04 PM |
