Old 01-30-2009, 05:53 AM
jeff.liu is on a distinguished road
memory card of FANUC 15MB
i tried to save the system data of FANUC 15MB with a 64M cf_card.but the screen displayed: memory card mounted error.then i use the controller to format the card.the screen displayed:executing.the processing of format lasted about for four hours.it seems like endless and then i have to turn off the controller to unplug the cf_card.i am wondering is it necessary to change the system settings. what kind of the card the 15M system can support? is 64M cf_card too big?maybe i need a 8M cf_card?
does anyone can tell me the reason?
thanks in advance for your help.
Old 01-30-2009, 11:11 AM
rajesh_1355 is on a distinguished road
A special Flash memory card will work on Fanuc 15MB system.
That u will hv to purchase from Fanuc it self.
It is older type card uses 15 vdc .
Old 01-31-2009, 02:55 AM
hello rajesh_1355:
thank you for your promptly reply.
now i know the reason.
Old 02-17-2009, 08:34 AM
xcoachx is on a distinguished road
Hallo, you need a SRAM card for 15 MB not other model !
Bye Andrea
Old 05-04-2011, 03:45 AM
vk_rathi is on a distinguished road
15 mb fanuc
pl.use SRAM CARD OF 1 OR 2MB memory.You may purchase it from fanuc or Ebay.
Old 05-05-2011, 08:11 PM
memoryman is on a distinguished road
You should use a PCMIA SRAM card. DO NOT buy from Fanuc. We use a 4Mbyte size so that we don't have to swap cards during installations. We manufacture
memory upgrades for this control as well as others.
go to TULIPMEMORY.COM
Old 05-05-2011, 08:41 PM
underthetire is on a distinguished road
You can buy fujitsu SRAM card on eBay. 2 mb is all you need. Large ones won't read.
Old 05-06-2011, 07:46 AM
"You can buy fujitsu SRAM card on eBay." we have no problems with any brand, including Pretec, Seiko Epson, Mitsubishi. Pay about US$ 150 for 4 Mb.
" 2 mb is all you need." 512k is all you NEED (maximum file size); larger is more convenient.
" Large ones won't read." untrue- we have been using 4 Mb for 15 years.
Old 05-06-2011, 04:38 PM
jimmy111 is on a distinguished road
Do you make one for a 21i-MA?
Old 05-06-2011, 07:50 PM
are you referring to the pcmcia card? These can be used on all Fanuc controls that have slot for them, including the 21ia..
  #11   Ban this user!
Old 05-07-2011, 12:11 PM
Yes. The PCMCIA card. I cant seem to get any to work. When i try to format them it says that the card is protected. If I try to write something gives me a "Memory card error 0007".
  #12   Ban this user!
Old 05-07-2011, 02:00 PM
kcho is on a distinguished road
You can't use ATA pcmcia card in a 15MB, they only work on Fanuc i Series. Like Memoryman said, Buy a fujitsu Sram Card.
Carlos
GE Fanuc 18i-MB: Memory Card Error 0030 andyinwi Fanuc 7 05-16-2010 06:12 AM
Where/How to buy Fanuc Memory Card marcwdci Fanuc 5 07-19-2008 08:57 AM
Fanuc 16i memory card jamie pinols Fanuc 4 02-25-2007 06:50 PM
Fanuc 6M-b max memory card A87L-0001-? Drew Machine Problems, Solutions , Wireless DNC, serial port 0 03-25-2005 07:08 PM
