Old 01-28-2009, 11:26 AM
PinMan's Avatar
PinMan is on a distinguished road
Unhappy Cutter Comp Issues
I am having a seriously frustrating issue with cutter comp. I am running a fixture with multiple parts and the first 6 parts run just fine, then I get to the seventh part and I get an p/s 041 alarm on the lead-in.
Code 041
Interference in CRC
Overcutting will occur in cutter compensation C. Two or more blocks are consecutively specified in which functions such as auxiliary function and dwell functions are performed without movement in the cutter compensation mode. Modify the program.
I dont think I really understand the wording of this alarm as I havent encountered it before, can someone explain it to me in a little bit more layman terms?
This is the section of program that it happens in:
/G01Z-.4F50.0
/G42D31X15.3112F8.526
/G03X15.9388Y-6.I.3138J0.
/G40G01X16.1887
/G00Z.475 <-- I get 041 alarm on this line
/X16.2313
/Z.1
/G01Z-.4F50.0
/G42D31X16.4813F8.526
/G03X17.1087Y-6.I.3137J0.
/G40G01X17.3587
/G00Z.475
/X20.3512
/Z.1
/G01Z-.4F50.0
/G42D31X20.6012F8.526
/G03X21.2288Y-6.I.3138J0.
/G40G01X21.4788
/G00Z.475
/X21.5212
/Z.1
/G01Z-.4F50.0
/G42D31X21.7712F8.526
/G03X22.3988Y-6.I.3137J0.
/G40G01X22.6488
/G00Z.475
M09
6 parts before the alarm run fine, I have checked the math, the leadin and leadout.... I am just really stumped.
Edit: Forgot to add Im running a Hardinge VMC 600II with a Fanuc 0-MD control.
Old 01-28-2009, 12:49 PM
SCRAPWOTSCRAP is on a distinguished road
Not an expert on your control, however, think the control is looking ahead to this line:
So the other six parts contain this line?? The "D" is dwell or cutter comp offset?? Some controls require a "dummy" move when invoking cutter comp or turning it off. Seems error message doesn't like G42 D31 together. Would like to see what the code looks like for the six good parts, or I could wait for someone who has same control as you, who knows EXACTLY what he is talking about, lol, sorry, had to reply I have felt your frustration in the past.
Old 01-28-2009, 12:56 PM
PinMan's Avatar
D is my offset value, the move from my rapid point to the point in my G42 line is my lead-in.
This is the first six parts that machined perfectly.
Code:
(JOB 3  CONTOUR)
(TOOL #3 - .500 S335 NIAGARA ENDMILL)
M06T3
G55
G00G90X.9162Y-6.S1505M13
G43Z.475H3
G00Z.1
G01Z-.4F50.0
G42D31X1.1662F9.7724
G03X1.7938Y-6.I.3138J0.
G40G01X2.0438
G00Z.475
/X2.0863
/Z.1
/G01Z-.4F50.0
/G42D31X2.3363F8.526
/G03X2.9637Y-6.I.3138J0.
/G40G01X3.2137
/G00Z.475
/X3.2562
/Z.1
/G01Z-.4F50.0
/G42D31X3.5062F8.526
/G03X4.1337Y-6.I.3138J0.
/G40G01X4.3837
/G00Z.475
/X7.0563
/Z.1
/G01Z-.4F50.0
/G42D31X7.3063F8.526
/G03X7.9338Y-6.I.3137J0.
/G40G01X8.1838
/G00Z.475
/X8.2262
/Z.1
/G01Z-.4F50.0
/G42D31X8.4762F8.526
/G03X9.1038Y-6.I.3138J0.
/G40G01X9.3538
/G00Z.475
/X9.3962
/Z.1
/G01Z-.4F50.0
/G42D31X9.6462F8.526
/G03X10.2738Y-6.I.3138J0.
/G40G01X10.5238
/G00Z.475
/X10.5662
/Z.1
/G01Z-.4F50.0
/G42D31X10.8162F8.526
/G03X11.4438Y-6.I.3138J0.
/G40G01X11.6938
/G00Z.475
/X13.8912
/Z.1
/G01Z-.4F50.0
/G42D31X14.1412F8.526
/G03X14.7688Y-6.I.3138J0.
/G40G01X15.0188
/G00Z.475
/X15.0612
/Z.1
Old 01-28-2009, 01:31 PM
Well I hope you're happy.....two of us stumped now, misery loves company???
Found this:
http://books.google.com/books?id=JNn...sult#PPA259,M1
Worth a peek??? At least it explains your error message in better terms.
Old 01-28-2009, 04:55 PM
timlkallam is on a distinguished road
Mr Pinman
G01Z-.4F50.0
/G40G01X16.1887 (change X16.1887 to X 16.1888)
/X16.2313
/Z.1
Youre using a .5 end mill so you must have .250 or more movement to deactivate cutter comp. you have .2499
one more tenth and it would work. Or you could change your D offest to .2499
16.1887-15.9388=.2499
Tim
Tim
Old 01-29-2009, 06:10 AM
PinMan's Avatar
Thank you so very much! I combed over the numbers a couple of times but still seemed to have missed that math
Gotta love the little things with CAM software lol.
Old 01-29-2009, 08:10 AM
I was told there would be no math!!! lol, good job, golf clap issued.
Cutter Comp Mooser Tormach PCNC 17 03-02-2012 07:37 AM
cutter comp issues toolmanwaz CamSoft Products 3 06-06-2008 06:29 AM
Cutter comp on an id hole< cutter diam.?? PaintItBlue Haas Mills 5 05-05-2008 06:30 PM
cutter comp in eia mrwright Mazak, Mitsubishi, Mazatrol 3 05-21-2007 07:53 AM
G17 to G18 Comp issues ParkerMillguy G-Code Programing 3 02-07-2007 05:46 PM
