Old 01-27-2009, 12:18 PM
sotos37 is on a distinguished road
Fanuc 0i-TC accurancy problem after power failure
Hallo
i have a problem with a Fanuc 0i-TC
After a power failure during operation ,
there is a problem with the X axis.
The x axis goes to wrong position without any alarm.
The inaccurancy is not the same every time. The mistake is from 0,1mm to 2mm.
With the jog mode there is no problem
In auto mode appears those mistakes.
i set up the cutting tool using offset.
Then the x axis get the zero points by (G00 U0 )
After this i try to cut in auto mode but there is inaccurancy in X axis
I have reloaded the SRAM but nothing changed.
how can i swap the x with z axis on the amplifier, in order to check if the problem is the ampifier?
Thank you in advance
Problem- 0T Power UP message (failure?) John3 Fanuc 1 01-12-2009 01:47 PM
X2 Minimill Power Supply Failure ozsteamdemon Australia, New Zealand Club house 8 12-08-2008 01:11 AM
What happens to the 2412 in a power failure? rustyolddo Sharp CNC 7 10-06-2008 09:29 AM
Fanuc power unit problem sbp Fanuc 3 03-25-2007 09:08 AM
Power Failure Detection Module 1ctoolfool Haas Mills 7 08-16-2006 12:35 PM
