Old 01-26-2009, 12:43 PM
daewo 8HC is on a distinguished road
Not recognized keyboard
i had deleted the ram of my fanuc controller series OT and now my keyboard is not working correctly. It's strange because when i am in the offset mode the keyboard is enable to introduce data this happen also in program mode but in this case the keyboard works like the compact version where the letters and the numbers are in the same key. Now, when i want to do the same action to set parameters, the keyboard doesn't work. A thecnician told me that i can't introduce parameter because the system initialize in EDIT mode and should be in MDI mode, but we can change it. Another solution was change the keyboard to the compact version (the daewo 8HC has a extended keyboard that includes letters) but we are still looking for it. If you have any idea about it, i'll be pleasured.
Regards
Old 01-27-2009, 12:15 PM
cncdiag is on a distinguished road
Parameter 38 bit 3 = 1 (full keypad) = 0 (standard keypad)
To reload parameters.
Push the E stop button in.
Power up holding in "Reset" and "Delete"push buttons.
Load all 900 series parameters.
Power off then back on.
Reload the rest of the parameters and diagnostics
Old 01-30-2009, 04:06 PM
Thanks cncdiag,
The parameter 38 bit 3 is equal to 0. We could found the standard keypad and it is working however i can't load parameters yet. I'm following these steps:
0. Turn on the system
1. Parameters push button on (DGNOS/PARAM)
2. Number push button on (No./L/Q/P) and insert the parameter number
3. (INPUT) push button on
4. No. push button on again and insert the bits array
But when i try to load the bits array (step 4) the keypad doesn't work. Do you know any idea about it? That's the procedure, right?
Old 01-30-2009, 05:58 PM
Press E stop in.
Set PWE = 1
MDI mode
Parameter page, reload parameters
Old 01-31-2009, 07:22 AM
hrh hrh is offline
hrh is on a distinguished road
Pull out all the plugs mounted on the I/O pcb.
Mode will become MDI with EMERCENCY STOP condition.
You can re-insert the plugs after you have reloaded the 900 parameters which you should re-input first manually.
Just IN- PBC Linear Now a Recognized AHTD Manufacturer Pacific Bearing Product Announcements & Manufacturer News 0 01-13-2009 03:10 PM
i hate this keyboard dertsap Canadian Club House 9 10-27-2008 08:09 AM
Problem- keyboard,, billwe Haas Mills 3 04-28-2008 08:57 PM
Keyboard problem BeliVolk General Electronics Discussion 2 07-10-2007 01:00 PM
keyboard jog HuFlungDung CamSoft Products 26 06-08-2004 09:17 PM
