Old 01-22-2009, 04:16 PM
SGARCIAM is on a distinguished road
Fanuc 10T Threading
Does anyone have a programing manual for Fanuc 10 T. We need a 90 deg pull out for the threading.
Old 01-22-2009, 05:33 PM
beege's Avatar
beege is on a distinguished road
I have one back at the shop. What do you need to know? Which G Code? G92? G76? G32?
Old 01-22-2009, 05:39 PM
g76
THANK YOU
Old 01-23-2009, 07:05 AM
beege's Avatar
Sorry, my manual says nothing about "pullout" angles. I use G32 exclusively. Maybe someone else could help...
On edit....
Best I can come up with is to check machine parameter 6212, change to .1, parameter 6213, change to 89°. It seems you can either have .1 X lead "chamfer" or 89° (not zero X lead or 90°) due to servo response.
Old 01-23-2009, 09:17 AM
dcoupar's Avatar
Some builders used an M function to turn chamfering on/off in threading cycles. This should be listed with your machine's M-codes if this is the case. I know on some Doosan lathes it's M76 (on) and M77 (off). Old Mori lathes were M23 & M24. This had to be in the block before the G76 command.
Old 02-04-2009, 01:00 PM
g-codeguy is on a distinguished road
If you are using the 2-block G76 call, then the middle pair of values for the P in the first block control pull-out. 00 will be a 90 degree pull-out.
G76P020029Q30
EDIT: The M-code option would be specific to the MB. None are used with the 2-block call that I am familiar with. Our Hitachi uses a single block G76. M24 would be no chamfer (90 degree pull-out), M23 uses what they call thread chamfering. Parameter 155 controls the length of the pull out, Parameter 155 contols the angle it pulls out over that distance.
G78 threading cycle on Fanuc 0i-TD Deco-Doctor G-Code Programing 3 01-06-2009 11:35 AM
Help with threading protrxrptr17 G-Code Programing 15 02-19-2008 05:09 PM
Fanuc 11T threading? rai Fanuc 12 05-13-2007 08:29 PM
Threading tapers on Fanuc control or Mitsubishi Tyler Durden G-Code Programing 4 04-04-2006 10:08 PM
taper threading using G76 on Fanuc OT sinha_nsit Fanuc 3 03-23-2006 04:31 AM
