Old 01-22-2009, 04:57 AM
NASOS is on a distinguished road
STOP ERROR SRVO-023 IN FANUC M-410i HW
The problem is that when i open the safety guard the robot stops and the axe 3 loosing several centemeters from its height ,from the point that it stops and then the message appears.Do you know the solution of the problem?
Thank you very much.
Old 01-26-2009, 04:18 AM
KaizenBlitz is on a distinguished road
This implies that the brake on the servo motor is worn and needs overhaul.
How much load do you have on the robot?
///M
Old 01-26-2009, 09:22 AM
hrh hrh is offline
hrh is on a distinguished road
Sometimes the grease for the harmonic drive enters the servo motor through the oil seal.
FANUC Robots have servo motors with built-in brakes. Possibly the brake is failing to hold the motor in position when the servo power is disabled and produces a following error for stop limitation.
SX3 External E-Stop error metalworkz Syil Products 3 03-03-2008 09:05 PM
Fanuc 18i-T looses position when E-stop hit. Radish Machine Problems, Solutions , Wireless DNC, serial port 1 02-04-2008 10:53 AM
Fanuc 0iMate-MB Emergency Stop Problem Mickey_D Fanuc 0 01-10-2008 02:24 PM
Milltronics Error 450 E-stop annoyance M_Controls Milltronics 11 09-20-2007 09:14 AM
Fanuc 0 M - Spindle Stop Uncle Buck Fanuc 2 06-30-2006 06:18 PM
