Results 1 to 5 of 5
Thread: ladder
    Oct 2008
    china
    ladder
    hello
    could anyone tell me how to save the ladder software than delete and update the ladder.thank you
    Registered viorel26's Avatar
    Jun 2007
    Romania
    Fanuc series ?
    for wich fanuc series? O,15,18,21,... ?
    Oct 2008
    china
    hello viore126
    thank you to replay very quickly
    this system is 18i and 31i
    thank you
    regards
    hong
    Sep 2008
    hello
    Quote Originally Posted by viorel26 View Post
    I need help too but about Fanuc model 0A and 0B
    Aug 2008
    UNITED STATES
    YOU CAN SAVE YOUR LADDER BY PLACING A PCMCIA CARD IN THE FRONT CARD SLOT AND BOOTING UP YOUR CONTROL HOLDING THE FAR LEFT MOST TWO KEYS UNDER THE SCREEN THIS WILL BRING YOU TO A FANUC BOOT SCREEN. YOU GO DOWN TO SYSTEM DATA BACK UP AND SAVE THE FILE PMC-RB.000 FILE AND YOU WILL HAVE A COPY OF YOUR LADDER. I WOULD ALSO RECCOMMEND DOING A SRAM BACK UP WHILE YOU ARE IN THIS SCREEN. AS FAR AS DELETING THE LADDER YOU DON'T WANT TO ATTEMPT THIS AS IT IS STORED IN THE FROM MEMORY WHICH IS A PERMANENT MEMORY. INSTEAD WHAT YOU WILL DO IS LOAD THE NEW LADDER AND THE CONTROL WILL PROMPT YOU IF YOU WOULD LIKE TO WRITE TO FROM WHICH YOU WILL HAVE TO DO IF YOU WANT IT STORED IN PERMANENT MEMORY. YOUR MAINTENANCE MANUAL SHOULD HAVE ALL THIS INFO IN IT. YOU CAN ALSO DO ALL THIS THROUGHT THE FRONT OF THE CONTROL BUT PEOPLE WHO DO NOT KNOW WHAT THEY ARE GETTING INTO NEED TO BE VERY CAREFULL AND ALWAYS MAKE SURE THE FIRST THING YOU DO IS TAKE AN SRAM BACKUP THAT WAY YOU HAVE SOMETHING TO GO BACK TO.
    1. Ladder editing
      By luca_r in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 06-05-2009, 04:02 AM
    2. 18T Ladder changes
      By CNC Solute in forum Hyundai Kia machine
      Last Post: 01-30-2009, 08:04 AM
    3. Ladder on 0T
      By guhl in forum Fanuc
      Last Post: 08-17-2008, 11:15 PM
    4. So whatsa ladder?
      By Dancy in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 01-18-2008, 05:57 PM
    5. PMC-LADDER
      By CHANDRU in forum Fanuc
      Last Post: 12-13-2007, 10:17 PM
