I have never seen any parameters that can be changed to achieve what you need. I will take a quick look through the parameter manual when I get a minute but I am pretty sure that the program will only return to the beginning if you are in Edit mode or a M30 is programmed.
My best advice would be to properly instruct you operator how to rest a program. It should be pretty common practice to always do a "edit", "program", "rest". Or you need to eliminate the need to rest the program when it is running. What is the reason that the program needs to be rest before it is finished?
Stevo
LinkBack URL
About LinkBacks
