Results 1 to 3 of 3
Thread: NO BUFFER WITH DRIP FEED
    May 2006
    Netherlands
    Hello all,
    Attempting to drip feed with buffer this morning on 2 machines using Fanuc OM-C I had a good result on one but the other machine keeps reading 1 line at a time.
    I have everything set the same. Parameter 390 bit 7 set to 1
    Don't know what else can be the problem.
    Can someone please help me as I realy need this machine to dripfeed with buffer. I'am using 4th axis on curved toolpaths so getting lots of small lines.
    Thanks!
    Registered dcoupar's Avatar
    Mar 2003
    390.7 should do the trick. The problem could be on the sending end... line delay, etc.
    May 2006
    Netherlands
    I use the same cable and same program. It realy doesn't work. Unpluged it and plug it in the Kitamura and works just fine!
  1. Need Help!- drip feed
    By kirby in forum Fanuc
    Last Post: 11-28-2009, 09:04 PM
  2. Need Help!- Drip Feed
    Last Post: 10-20-2008, 10:21 AM
  3. Drip feed?
    By MrWild in forum Dolphin CADCAM
    Last Post: 02-24-2008, 11:33 PM
  4. BMC-20 w/Max II drip feed......
    By GPena in forum HURCO
    Last Post: 10-31-2007, 01:37 PM
  5. Drip Feed
    By camtd in forum Surfcam
    Last Post: 07-31-2006, 07:09 PM
