Results 1 to 2 of 2
Thread: 0T Power UP message (failure?)
    Mar 2007
    On power up this morning, my Fanuc 0T control does not complete its power up procecess.
    The CRT monitor shows: 0615-11 in very large characters in the middle of its screen and below that it shows: PMC: XB7A-06 NOT READY.
    Yesterday the machine powered up fine and ran fine. Does anybody have any suggestions on what this means and how I can begin troubleshooting the cause?
    Thanks,
    John
    hrh
    hrh is offline
    Jan 2009
    South Africa
    See if you can view the PROGRAM or POSITION screen by pressing the buttons on the MDI panel.
    If you can view these screens check the following Diagnostics (Press PARAM / DGNS button twice):
    21 = 00110000 is a usual condition for emergency stop input and feedhold ok.
    121 same as above
    (the other bits may be any condition as long as bit 4 is "1")
    Also check the machine side +24V power supply and the fuses or non-fuse breakers.
    Check overloads and any error lamps on the operators panel.
    If you cannot select and view ANY screens then it is likely a control PCB failure similar to Watchdog alarm or some other atomic animal.
  1. X2 Minimill Power Supply Failure
    By ozsteamdemon in forum Australia, New Zealand Club house
    Last Post: 12-08-2008, 02:11 AM
  2. What happens to the 2412 in a power failure?
    By rustyolddo in forum Sharp CNC
    Last Post: 10-06-2008, 10:29 AM
  3. Unspecified failure message
    By Chrisjh in forum Syil Products
    Last Post: 07-04-2007, 08:57 AM
  4. Power Failure Detection Module
    By 1ctoolfool in forum Haas Mills
    Last Post: 08-16-2006, 01:35 PM
  5. (Bridgeport w/ Heidenhain) Yellow Power Button Failure
    By griffithbuilt in forum Bridgeport and Hardinge Mills
    Last Post: 04-14-2006, 03:45 AM
