Old 01-11-2009, 11:48 AM
teal854t is on a distinguished road
Mori lather Zt1500 18i : turret Y-axis homing
It is a dogless system. Y-axis for turret was off and tried changing it with grid shift (1850) but couldn't do it. whenever I change 1850 value I need to power it down and re do the Y-axis home. I couldn't seem to get it at center of the part. It's always off center. I must not be doing it correctly. I enabled zero point enable, jog the y-axis close to center about 2mm and press zero return on and zero return y-axis. bit 1 appears on 1815 y-axis. Is is a correct way of I have to find the center position myself and turn on the 1815 myself?
Old 01-11-2009, 03:10 PM
djezowski is on a distinguished road
Its very offten problem with machines equipp Y axis.
Its take a long time to get Y in center when use #1850
Go the lazy way and do following:
First have normal stage: #1815.4 = 1
Find center in Y and X by dial indicator.
MDI
PWE = 1
#1815.4 = 0 for X and Y
RESET (just press key)
Ignore P.OFF request!!!
#1815.4 = 1 for Y
MPG
Reset INCREMENTAL on SCREEN
go to X up to have exacly travel value given for this holder with you use.
(ex. if for holder is 320mm - it means your X=0 must be 320mm UP from chuck zero point.)
MDI
#1815.4 = 1 for X
PWE = 0
POWER OFF/ON machine.
Good luck
Darek
Homing a rotary axis? Harryman WinCnc 1 12-24-2008 11:19 AM
Newbie- Homing axis in G-Code Des Jacobsen Mach Software (ArtSoft software) 0 10-21-2008 01:06 AM
Mori Seiki SL 0H turret tapserv Mori lathes 4 01-20-2008 01:01 PM
homing z-axis wadero General Metalwork Discussion 1 08-20-2007 04:30 PM
