Fanuc oi-mb controller How do I get the controller to pull the programs from the memcard? It displays the programs on the disc but I cannot use them. The machine can write to the card but cannot read from it. I get a 071 BP/S Alarm My card is a 2 gigabyte compact flash inside an adapter. |
| You're just trying to READ a program from the M-CARD to the Fanuc memory, correct? EDIT mode PROG function [ > ] (rightmost soft key) [CARD] (You'll see a directory of the files on the card) [F READ] Type in the file number, i.e.: "1" [F SET] Type in the program number to store it under, i.e.: "1234" [O SET] [EXEC] Try that and let us know if you still get the alarm. |
| Thanks a bunch! But now I believe the memory maybe full on the machine. Once I followed all the steps you told me,the transfer process stopped all of a sudden. Then When I tried again I got the same message again and could not repeat the steps you gave me. I looked at the programs dir and as far as I can see it appears that it displays 0 space. Is it possible that there is not enough space on the machines drive? If so how can I delete the older programs? Can I run the program from the memorycard? |
| To delete old programs: EDIT mode, PROGRAM function, type the O number of the program you want to delete, i.e.: O1234, then press the DELETE key. If your machine has a TAPE mode, you should be able to run from the card instead of the MEM. Set your I/O Device to 4, then select TAPE mode (RMT should display in the lower left). I suggest you start in single block until you're sure it's doing what you want. Press [ > ] soft key, until you see [DNC-CD]. Press [DNC-CD] Type the file number, i.e.: 1 then press [F SRH] Press the [DNC-ST] soft key. Press CYCLE START |
#11
| Yes it has tape mode. Can you give me some head start steps to seeting it up. As in Were on the computer does the program need to be stored? Are ther any special netork settings I need to do.? The reason I am asking all these question is because I dont have a manual. I believe if I had one I could figure it out. Thanks for the help |
| help reading a 16C621A.. | d_mc_a | PIC Programing / Design | 4 | 01-24-2009 10:00 AM |
| Reading workingoffset values | rui.costa | G-Code Programing | 4 | 12-20-2007 02:27 AM |
| problem with cnc reading bob/cad OR something | jr2840 | Bridgeport and Hardinge Mills | 4 | 09-08-2006 11:28 AM |
| Reading only new posts | PEU | Forum Questions or Problems | 1 | 06-04-2005 10:22 PM |
| CNC recommended reading? | margni74 | General Metal Working Machines | 7 | 12-29-2003 09:28 PM |
