Old 01-09-2009, 08:33 PM
Jeff_Mezzo is on a distinguished road
Fanuc 18i-T "1114 main spindle orient fault"
Having trouble with a "1114 main spindle orient fault" on a hardinge TT-65. It has a fanuc 18i-T controller. Any help would be much appreciated.
Old 01-11-2009, 11:35 AM
teal854t is on a distinguished road
We have Mori Seiki mill with 18i and had problem with spindle orientation for tool change parameter 4077 worked for us. Try changing parameter 4077 or check out this
http://www.machinetoolhelp.com/Repai...ientation.html
Old 01-12-2009, 05:21 AM
rlabonte18 is on a distinguished road
don't change param 4077 it is for turret orientation on your tt-65.
Old 01-28-2009, 08:30 PM
Thanks for the input guys, ended up being a bad drive, main spindle drive to be exact. Thanks again for the input.
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 12:15 AM
Need Help!- Bridgeport Int. 316 "Spindle Orient Alarm" mbpp Bridgeport and Hardinge Mills 3 08-28-2008 10:39 PM
"SPINDLE DRIVE FAULT" offroadxx Bridgeport and Hardinge Mills 1 01-15-2008 08:38 PM
V2XT error message "DRIVE FAULT detected (0,z,y,x) check log" rfdoyle Bridgeport and Hardinge Mills 4 10-08-2007 03:35 PM
Add "View New Posts" to "Main Menu" Mr.Chips Forum Questions or Problems 4 04-21-2004 10:54 PM
