Old 01-09-2009, 04:00 PM
capital is on a distinguished road
4th axis issues
We have a yang machining center with a fanuc omd control. It has a forth axis(rotary table). We can get the forth axis to turn manually and independantly(in a program) however, we cannot seem to get it to rotate simultaneously with any other axis. Is this a parameter issue or what. Also we occasionally get a 444 error that is not in the manual what is it?
Old 01-09-2009, 04:26 PM
ChattaMan is on a distinguished road
4th Axis?
Sounds like you have an indexer not a 4th axis. You have not given enough info to work on.
Part prog sample would help.
In the prog, is it moved independantly by an M code or a A axis command?
Is the 4th axis programmed separately on it's own control panel?
What make/model is the 4th axis.
Does your 444 error appear on your Fanuc control or 4th axis control?
Old 01-09-2009, 04:36 PM
avtechmachine is on a distinguished road
I have to agree with ChattaMan, your 4th Axis popery is a Indexer instead?
Old 01-09-2009, 05:18 PM
The 444 error appears on the fanuc control. In the program the forth axis is moved independantly by a B command which I assume is the same as an A command.
Old 01-09-2009, 05:30 PM
Alarm 444
Ref. to Fanuc Maintenance manual servo alarm section, you need to check DGN number 720 to 727 to see which bit number is equal 1
make sure to check DGN not parameter
Ahn Vuong
ahnv@avtechmachine.com
Old 01-09-2009, 05:40 PM
Alarm 444
also need to check on the servo drive inside of the electrical cabinet to see any alarm number displace
Ahn Vuong
Old 01-10-2009, 08:09 AM
hrh hrh is offline
hrh is on a distinguished road
If alarm 444 then this is a proper 4th axis integrated in the machine.
Check Diagnostic 723 when the alarm appears as well as alarm indications on the 4th axis servo amp.
The option for simultaneous 4-axes interpolation and or cylindrical interpolation is required for the 4th axis to move together with the other three axes.
Usually a M-code is required to release the brake before moving the 4th axis.
You should then command a M-code again to lock the brake when the cutting force on the steel component is high.
Therefore check if the 4th axis unit has sufficient air for releasing the brake and that the pneumatic valve is operating as well when commanding clamp or unclamp.
Old 01-10-2009, 10:35 AM
"Usually a M-code is required to release the brake before moving the 4th axis.
Therefore check if the 4th axis unit has sufficient air for releasing the brake and that the pneumatic valve is operating as well when commanding clamp or unclamp. "
Just in case if you need to know the M code for clamp & unclamp for this VMC, they are M10 and M11
Ahn Vuong
Old 01-12-2009, 12:34 PM
How do I find out if I have the option for 4-axes interpolation installed?
Old 01-12-2009, 01:10 PM
hrh hrh is offline
Parameter 914 bit 7 = 4th axis interface
(Control should then have parameters from 8400 to 8499)
Parameter 907 bit 2 = Simultaneous 3 axes control
Parameter 913 bit 4 = Simultaneous 4 axes control
Parameter 917 bit 0 = Cylindrical interpolation
bit# 7654321
bit# 0000000
BACK UP THE CONTROL's DATA BEFORE ATTEMPTING ANY ADJUSTMENTS.
  #11   Ban this user!
Old 01-12-2009, 02:18 PM
DGN 723.5 on when alarm 444 what does that tell me
  #12   Ban this user!
Old 01-13-2009, 06:27 AM
mopar499 is on a distinguished road
shouldn't the bits be?
76543210
Need Help!- Issues with Y axis Projex Tormach PCNC 6 12-16-2008 06:04 PM
Need Help!- 4 axis viper 950 feed issues coolbreeze General Metalwork Discussion 2 06-14-2008 06:20 AM
Some advice needed on X-Axis belt issues. kumaichi Industrial Hobbies (Support forum) 14 02-21-2007 08:47 AM
BP Series 1 with Mach3- Z axis limits issues bbuonomo Bridgeport and Hardinge Mills 6 10-13-2006 04:39 AM
Arrow key movement issues on Y axis. chrispy Mach Software (ArtSoft software) 8 08-25-2005 11:56 AM
