| I assume that the Mori is using FS-10T with Digital servo interface. The alarm is very likely SV 027 Z DGTL. If you have reset the parameters then you should also have had SV 027 for the X-axis. I don't understand why the X-axis is ok but not the Z-axis. All I can think of is some finger trouble when you re-entered the parameters by hand. If you have the parameter list, I suggest that you re-check the Z parameters thoroughly starting from 1800 to 1899. You should especially check the following parameters: 1806 1865 1866 1869 1879 1891 Better still if you have a parameter backup on your PC. Just read in the parameters via the RS-232 port after the option parameters were set in the IPL screen. |
| FANUC 6T ERROR 401 SERVO | cjchands | Fanuc | 11 | 04-22-2009 11:09 AM |
| Problem- 1982 fanuc 6m control (Enshu) 401 servo error | Rob Lacy | Fanuc | 7 | 10-26-2008 02:51 PM |
| Z AXIS SERVO ERROR, NEED HELP | bgmnn | HURCO | 3 | 12-11-2007 12:09 AM |
| X servo error on tm-1... | superrat | Haas Mills | 5 | 04-16-2007 11:14 AM |
| servo error | JimS | General Electronics Discussion | 1 | 08-04-2003 09:23 PM |
