Old 01-07-2009, 11:47 PM
esadaddy is on a distinguished road
Unhappy fanuc series oi-mb Setting tool height?
Please can some one give me a kick start on how to sett tool height on this cnc machine I am using? It has a fanuc series oi-mb controller and it seems very difficult to understand. All my g-codes are produced on my cam software and then loaded to the machine.
I haved used the fadal machines before and it was very easy but this one uses jargon I cant seem to mentaly decode.
Can someone give me a kickstart on what direction I take to seeting tool height?
The machines are Manford machines and have never been used. Knowone knows how to use the thing.
I have uploaded many programs to previous machines and have set them up but this one is a lil harder.
Old 01-08-2009, 12:48 AM
dcoupar's Avatar
You can set each tool individually to each part, or you can set all tools to a common height, such as a tool-setter or 1-2-3 block or ???. If you set them all to a common height, you adjust for part height difference in the G54-G59 Z work offset.
So, in that case, bring the tool down to touch the tool-setter. Go to the offset display, and move the cursor to the Z GEOM column for the offset you want to set. Type Z 0 MEASUR. That will set the offset for that tool so that Z0 is the top of the tool-setter. Then, find out how much higher (or lower) the part zero is than the tool-setter, and enter this value in the G54 (G55, G56, etc.) Z.
Old 01-08-2009, 01:15 AM
Thank you, I will try this and see what happens.
Newbie- Series II Boss 6 Tool Setting btcoutermash Bridgeport and Hardinge Mills 2 04-06-2008 07:53 PM
Setting up Z axis tool holder height above table EL34 DIY-CNC Router Table Machines 3 07-27-2007 03:28 PM
Fanuc tool height offset H~ hkelsey Post Processor Files 2 06-14-2007 11:01 PM
Setting tool height is300driver General Metalwork Discussion 12 11-14-2006 06:28 PM
Setting Tool Height JAGYZF Commercial CNC Wood Routers 5 03-22-2005 07:22 AM
