Hi everyone , i find this forum by looking to solve my lathe problem , The problem is : the machinist change the battery on lathe and they had this message : ram parity error the model is fanuc 10t on a Morei Seiki lathe year 1988. i don t have any book or anything else about the pmc parameter or anything else ! does someone have it for this machine and controller ??? Thanks a lot ! the production is stopped since last friday ! |
| I ve got the procedure for re install the NC parameter of my mori seiki lathe, I did it and it work, but i still have an alarm ALM344, " A VALUE AUTHER THAN 8 . 10 OR 12 WAS INPUT TO THE PARAMETER AS A SETTING FOR THE NUMBER OF STATIONS D108 OR D109 " I CAN T SEE THE PARAMETER D108 IN MY DATA PAGE !! THE NUMBER OF DATA STOP AT A074 DOES SOMEONE KNOW WHY ???? PLEASE NEED HELP THE TECHNICIEN FROM TORONTO DON T KNOW WHY EITHER ! |
| i did it , i was nt able to change the date table for D0108, but i find how did it , i had to press the "double arrow key" and the "simple arrow key " at the same time to change for D108 so my data parameter are set But the problem is , i m still have the S027 z dgtl servo error what have i to do ? thansk a lot |
PM your email. I could send you some of 10T parameter. |
I have an SL-25 with a Fanuc 10T control and lost the parameters. I am told I need parameter from someone with a Mori with a close serial # and your is only one digit off. Could you reply to this or even phone me at 306-768-7771 Thank you in advance!! |
#12
Wow you got lucky. That is the fastest I have seen someone get there machine running after losing all data and having no backup. My suggestion now is to backup EVERYTHING. This is the first thing that should have been done when you put power to the machine. On the 10series fanuc you cannot punch out your PMC data via RS232 so you have to write it all down. Get all of your macro programs out of the control as well. Stevo |
| Need Help!- fanuc 10T ram parity error | jolulank | Fanuc | 14 | 01-04-2012 04:23 AM |
| Need Help!- Fanuc 3M ROM PARITY ERROR | gyrodog | General CNC (Mill and Lathe) Control Software (NC) | 0 | 12-12-2008 04:45 AM |
| Fanuc 0M-C --- 914 Ram parity error | rajappa | Fanuc | 4 | 06-10-2008 10:17 PM |
| Fanuc 16M system software load ROM Parity Error | ljmapet01 | Fanuc | 2 | 06-07-2007 11:42 PM |
| Fanuc 15 M Ram Parity Error(system Lable Lost) | SBAGHAEI | Servo Motors and Drives | 1 | 06-07-2007 04:40 PM |
