Old 01-03-2009, 02:17 PM
aimcnc is on a distinguished road
memory card problem on robodrill
Hi, i have just purchased a 1999 robodrill and the onecnc 4 axis package to machine some small 3d work, problem is the robodrill wont accept the flash card i use on the oi control on my lathe. The robodrill control is a 16im (b0f1), i have tried my 2G and bought a 512MB card but it wont read them or format them. Any help would be great. I have read about the smaller ata flash cards is it worth giving these a try? and where can i find one?
Many thanks,
Sam
Old 01-30-2009, 02:44 PM
gwiz is on a distinguished road
SRAM Cards
Early i controls (16ia, 18ia) could only use SRAM cards. We were told by GEF that putting an ATA Flash in the original units could damage them because of the 3v/5v difference in the cards. I have tested some SRAM cards from Epson (can't get them anymore) and Vikant Corp. model SA5002-P. They work fine. The Sram is more expensive but they work.
As far as the smaller flash card i believe you mean a Compact flash cards. you can use them with an adapter (ATA adapter) in a newer Fanuc control.
Regards,
Old 03-19-2009, 12:00 PM
shibi is on a distinguished road
Many thanks,
Sam
Sam,
We have a '00 Robodrill T14iAL and over the years we have tried all sorts of memory cards and mocrodrives on it. You'll need to use a smaller CompactFlash card (I assume you have a CF-PCMCIA adaptor). The Fanuc 16iM-A control can only handle cards up to 256MB. I have a small stash of new 128MB cards that I hide in a supply cabinet so that we'll always have them in case the flash card manufacturers stop making them.
Interested? I'll sell you one for cheap.
-S
Old 03-20-2009, 04:38 PM
Hi, thanks for the replies,
Shibi, i bought a 128MB Scandisk CF but that didn't work either. After a lengthy conversation with GEF i found the very early 16i controls do indeed use Static RAM cards (spot on gwiz) Managed to find an 8MB pretech card for £180.
Next problem........The new laptop i bought to run the cadcam software had an express card slot, not the pcmcia. So i had to buy a omnidrive SRAM reader/writer (£350) then had problems running it with vista. Nightmare.
Sods law the first 3D program was 9.5MB
After all this i found my robodrill has the remote option (i was told it didn't!!!!) so i can just run it from my old dnc software.
Suppose you live and learn, just wish my mistakes weren't so expensive!
Mori seiki MV40E memory card problem v.sundermoorthy Mori Mills 3 04-20-2009 02:35 PM
Need Help!- memory card rajanvadakkepat Computers and Networking 1 08-26-2008 01:54 PM
Need Help!- memory card read problem with 0iMC jhartleyjr Fanuc 6 05-29-2008 11:00 PM
Memory Card Cnm 1b avaitsis Machine Problems, Solutions , Wireless DNC, serial port 0 07-27-2007 03:45 PM
Memory card M-man Fanuc 10 07-17-2006 03:00 PM
