Old 12-30-2008, 01:52 PM
teal854t is on a distinguished road
Fanuc 18I with error 410, 411, 438
Hi
We have Mori mill with Fanuc 18i controller. We're getting error 410, 411 and 438 for axis A and axis B. Is there any parameter that i can change to correct for error 410 and 411?
Old 12-30-2008, 05:39 PM
kklaver is on a distinguished road
Alarm Codes
Teal,
For what it worth here is a copy from the Fanuc manual Series18i. Hople this Helps you out.
410 SERVO ALARM: n–TH AXIS – EXCESS
ERROR
One of the following errors occurred:
1) The positional deviation value when the n–th axis stops exceeds the
value set in parameter No. 1829.
2) In simple synchronous control, the compensation amount for synchronization
exceeds the value set in parameter No. 8325.
This alarm is issued only for the slave axis.
411 SERVO ALARM: n–TH AXIS – EXCESS
ERROR
The position deviation value when the n–th axis (axis 1–8) moves is
larger than the set value.
Refer to procedure of trouble shooting
438 n AXIS : INV. ABNORMAL CURRENT
1) SVM: The motor current is too high.
2) α series SVU: The motor current is too high.
3) β series SVU: The motor current is too high.
Old 01-07-2009, 09:19 PM
machinist_1 is on a distinguished road
I have a Fadal with the 18i. I had the same errors 410-411, it turned out to be a bad scale on my X. (I have scales and encoders) don't know if that matters.
Old 01-30-2009, 06:18 AM
mluqman is on a distinguished road
Smile
Hello, is this error come out after CNC turn on or when moving?
if this error come out just after ON, suspect the problem from your ServoAmp
(assume A-axis and B-axis in one servoAmp). If One by One, try to swap against another good-axis ServoAmp.
if not may be you could adjust the par 1829 to higher but not high, do graduall till the error not appear anymore.
maybe this link could be useful http://cncfanuc.blogspot.com
Old 01-31-2009, 06:54 AM
hrh hrh is offline
hrh is on a distinguished road
If the machine was working correctly before then there is no point in adjusting the servo error limits for stanstill and movement.
You need to find the cause first.
Some Mori machines use the A and B axes synchronously to drive the column up and down.
What are the symptoms and describe the A and B axes? (Dividing head with two rotating planes or two motors connected synchronously for a linear axis?)
Old 10-29-2009, 09:27 AM
A and B axes are for rotaty and tilt table made by Nikkin. There's no symtoms, the indexer/rotary unit ran fine for a hour or some times the whole shift. Then stopped and came up with 411. We had to turn off the power and restart it. We have 10 Mori with Nikken indexer/rotary tables. None of the have that problem except of that perticular one. We swapped the Nikken unit, cables, board and rand fine for about 3 months and comes back. It's an ongoing problem.
Old 10-29-2009, 09:32 AM
underthetire is on a distinguished road
Axis alarm
You need WAY more details if you really want help on this forum. Model of machine, type of drive unit, does the Nikken have scales ? How/when does it fail? During start of move? During move? Resting? Etc..
Old 10-31-2009, 12:40 AM
fanucman is on a distinguished road
keep it simple.. does the 438 come up on power up? does the amp get a 8 or 9 on display?
its probably gonna be a bad amp.. meg motors..
is this an axis with a dual ball screw.. if it is you probably need to have it realigned...
Old 12-02-2010, 01:55 AM
mattpatt is on a distinguished road
Need some help.
Fadal 3016FX VMC. Fanuc 0i control.
Just had an alarm come up:
438 X AXIS: INV. ABNORMAL CURRENT
What's the problem?
I'm in Thailand, and have received quotes for between $1000~$2000 to solve it, but that's before anyone has been to see what's going on.
Any advice?
Old 12-02-2010, 06:56 PM
Originally Posted by mattpatt View Post
Need some help.
What's the problem?
Any advice?
probably a bad servo drive.. check x axis servo motor and cables for short.. you need to see 100 mega ohms to ground on all 3 legs.. if you do then drive is bad. .if you see a short you need to check motor and cables..
  #11   Ban this user!
Old 12-03-2010, 12:13 AM
Thanks for your reply.
I'm a real novice at this and don't know where or what to check.
As I said, a couple of service companies have mentioned figures starting at $1000 to fix it. Does this sound right?
Fanuc Error 449 dhiruj Fanuc 7 01-04-2009 12:18 PM
Need Help!- Fanuc 0T error 310,320 and 520 kfmc General CNC (Mill and Lathe) Control Software (NC) 3 10-01-2008 03:49 AM
Need Help!- Fanuc OT Error 410 jgj Fanuc 7 07-07-2008 12:08 AM
FANUC OMB Error malasjo Fanuc 2 12-31-2007 05:23 AM
Fanuc 6MB Error LED tsalpha Fanuc 4 01-05-2007 08:51 AM
