| I wrote a quick and dirty macro to give partial compatability with a Yaznaq G13 on our 518MSC (Fanuc 18M) Mori Seiki. I say partial because Yaznaq uses an "L" as one of the optional augments. This is not possible on the Fanuc as "L" is not normally supported in Macro B. You would need to look up several machine parameters and change the variables to match your 0m. I can stop by the shop and get a copy to post here later if there is interest. Note again this is the Yaznaq type which does not have ANY Z axis movement. You must use a G01 Z before the G13 and a G00 Z after... Someday I will "Upgrade" the Macro to be more like the HAAS usage of a G13. But at the time I was handed a cart with all preset tooling and ready to run Yaznaq code that I had to edit into something we could run today and it was full of G13's. You might also try the G65 Pxxxx method if you don't want to add a G13 command. |
| Hi alexcomo This is easy to do just right the Gcode that you need you don't need a macro T5M6 M8 G54 S2850M3 G90G0X-1.0985Y.3569 G43Z.2H5 G1Z0F20. G3X0.Y1.55Z-.16I1.0985J-.3569 Z-.36J-1.155 Z-.56J-1.155 Z-.76J-1.155 J-1.155 G0Z.2 M9 M5 G0Y5.5 M30 This will do a spiral down .200 per pass on a 2.56 dia hole x .760 deep .250 cutter centre being X0Y0
__________________ Mactec54 |
WERY WELL!!Thank you all for help!!!Grazie! First of all ....sorry for my english!!!!! Specification:for spiral i mean work an hole with archimede spiral. I think is the more efficent way for empty a round hole. Skullworks please post it when you can. G13 is the native way to do this on fanuc 18, isn't it? Hi all!!! |
| Hi all. Thank you Luky...Which program you have used for make the pic? Here is what I mean for archimede spiral http://www.math.it/spirale/spirale-archimede.htm The native Gcode for Fanuc 18 archimede spiral is only G2 or G3 but you need to put into the command line the adress L (number of revolution) or Q( radius increment for spiral revolution).This function is not available on the fanuc 0i-mc(absurdity!!!!!!!!!!!!) Tomorrow I'm going to test my dirty macro in my shop! here is a preview % :9019(INTERPOLAZIONE FORI) (X E Y POSIZIONE CENTRO CERCHIO #24 #25) (I RAGGIO #4) (W NUMERO DI GIRI DI SVUOTAMENTO #23) (D PREFORO #7) (E EVENTUALI GIRI D'ELICA #7) (K ALTEZZA DI INIZIO #6) (Z PROFONDITA CON SEGNO- #26 DISTANZA DAL PUNTO K) (F AVANZAMENTO #9) (#500=NUMERO UTENSILE A MANDRINO MEMORIZZATO DA MACRO CAMBIO UT) #501=#5003(MEMORIZZA ALTEZZA IN CUI SI TROVA UT PRIMA CAMBIO MACRO) #502=#6 #503=#9 #505=#4 #506=#26 #507=#23 #100=#[13001+#500](RAGGIO FRESA) #106=[#502+#26](PROFONDITA IN Z) #107=#505-#100(RAGGIO FINALE INTERPOLAZIONE) #110=[[#107-#100]/#507]/360(INCREMENTO RAGGIO A STEP) #112=0 #111=#100 #114=0 #113=360*#23(VALORE TOTALE DEGLI STEP) G0#24Y#25 G52X#24Y#25 Z[#502+2] G1Z#106F[#503*0.7] N1WHILE[#114LT#113]DO1 #112=#112+1 #120=#111*COS[#112] #121=#111*SIN[#112] #111=#111+#110 G3I#120J#121 END1 G1X#107Y#25 G3I-#107 I-#107 G0Z#501X0Y0 G52X0Y0 M99 % |
| Hi ALEXCOMO I think luky is showing you is my program You don't need a call for how many ( revolution's ) the Z step & J keeps it going around change it to metric numbers & it will work in your control The link you have posted is a face milling spiral which you would have to go back to the centre for each Z step to make this work not really a good way to do it Just drill a hole & use like what I have done you only need ( I ) ( J ) ( Z ) & ( G3 ) moves to make this work I use this for roughing all the time it can have arc on arc off if needed when I'm running one I will take a movie of it it is very cool way to do milling
#10
| These are the macros that I use for spinning a hole. You don't need to drill out the center of the pocket. This climb mills to depth. I have written this and run it on all my Fanucs. I have not run it on a OM series. However as long as you have macroB programming this will work. Q=pick in Z, W=starting depth, E=dia to spin, K=cutter dia, Z=final depth, T=tool number, M=coolant code, X=x-center of hole, Y=y-center of hole. O0001(MAIN PROGRAM) #500=3.(CLEARANCE PLANE) G65P8001Q.025W.1E.5K.25Z.9T10M8X0Y0 M30 O8001(C-BORE RAMPING ROUTINE) #2=10000(ROUNDING) #12=#17 #13=#23 M6T#20 #8=#8/2 #6=#6/2 #1=0 #15=[#8+#6]/2(ARC IN) N100 IF[#6GE#8]GOTO260 G0G90G55G80 X#24Y#25Z#500 Z[#23+.1] G1Z#23 G91G1X[#8-#15]Y-[#15-#6]M#13 G3X[#15-#6]Y[#15-#6]J[#15-#6] N150G3X0Y0I-[#8-#6]Z-#17 #23=#23+#17 IF[#1EQ1]GOTO400 IF[ROUND[[#23+#17]*#2]/#2GE[ROUND[#26*#2]/#2]]GOTO300 GOTO150 N300#17=#26-[#23-#13] #1=1 GOTO150 N400 #23=#13 #17=#12 #1=0 G3X0Y0I-[#8-#6] G3X-[#15-#6]Y[#15-#6]I-[#15-#6] G90G1X#24Y#25M9 G0Z#500M5 N200M99 N260#3000=10(CUTTER DIA. TO LARGE) Stevo |
#11
| Hi Stevo Does your macro cut the dia of the cutter all the way down or the whole surface of the hole all the way down You don't need to drill a hole with my Gcode It is a place the chips can go when cutting steel it's a lot easer on the cutter to have a hole if you are going more than .500/12.7mm deep
#12
| This will cut around the diameter of the tool. So it will spin the hole dia that you specify - the tool dia. This will move to the center of the hole above the part. It will arc to the diameter of the hole then spin all the way around the hole moving down in the Z the pick distance specified with Q value. It will do this until depth set by Z is obtained then it will make 1 idle pass at the bottom to remove the material left from previous pass. Then it will arc back to the center of the hole and retract to the R-plane. We do a lot of steel, SS, Inco, Hastaloy. I have never drilled out the center of the hole first. Althought it never hurts for chip removal and less tool wear. This program runs as smooth as a baby's butt, a lot of guys are very happy with running this mainly because of the versatility. You might find that you won't have to drill out the hole first. This macro just runs one hole. I have these macros set up for doing mutiple holes on a BC with a rotary axis and non rotary axis machines. I also have them set up to use the tool radius in the offset page so you can make adjustments on the fly without resetting the program. I have also set them up for holes not on a BC but with multiple holes at different locations. This way would be set up with a macro modal call then just specify the X,Y locations. Let me know if this would be an application that you could use the other macros so I can post them. Stevo |
| Fanuc bolt hole macro | Machinist3 | G-Code Programing | 4 | 05-23-2008 10:43 AM |
| spiral macro ? | cyclestart | G-Code Programing | 4 | 03-23-2008 09:42 PM |
| 400x330x12mm AL hole milling | fantasy2 | Employment Opportunity | 0 | 05-06-2006 10:54 AM |
| G12/G13 hole milling | JFettig | Mach Software (ArtSoft software) | 14 | 03-10-2005 08:23 PM |
| Milling a hole | igorko | General CAM Discussion | 25 | 01-30-2004 05:55 AM |
