Old 12-22-2008, 09:40 AM
mt92 is on a distinguished road
Question Fanuc 6MB feed with no spindle rpm????
Is there a parameter that I can change so that I can use a feed rate without my running the spindle. When I try it now it just stops with no alarm.
Mike
Old 12-22-2008, 10:00 AM
avtechmachine is on a distinguished road
You may want to program it inch per minute instead?
Ahn Vuong
Old 12-22-2008, 02:22 PM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
Mike
I don't think there is a parameter but you might be able (but you shouldn't!!)to override it by using Keep relays.
Why do you want to run the machine without the spindle running?
Maybe there's another way to do what you want to do.
Stefan Vendin
Old 12-22-2008, 02:58 PM
jimwymz is on a distinguished road
Mike,
Fanuc Controlled Machining Centers control Feed in two ways, by G-Code.
1.) G94 Feed per Minute (This is usually the Default){see notes below}
or
2.) G95 Feed per Rotation (This Not Default, It is used for Tapping Primarily, and can be Used for "Controlled" Positioning {I know of a User who has a Tool Made to Pick Up a Bushing from a Gravity feed chute, and Presses it into the Just Reamed Bore!}
Fanuc Controlled Lathes control Feed in two ways, by G-Code also.
1.) G99 Feed per Rotation (This IS Default)
or
2.) G98 Feed per Minute (This is Not the Default),
G98 is Usually used on Lathe with Bar Feeder or Bar Puller because Most Lathe Logic will NOT ALLOW Axis Movement while Chuck is Open.
{see notes below}
{NOTES}
On either Machine Tool When you change (By M-code ) from the Default Feed Control Code, You must for Safety Sake Add the Default G-code after you have finished using it at the NOT DEFAULT Feed Mode back to the G-code for the Default Mode.
Be sure to be aware of this- If you are in the wrong Mode for the Feedrate, your crash will teach you to not Do that again!
A Smart Man Learns from His Mistakes....
A Wise Man Learns from Everyone's Mistakes...
JimW
Old 12-23-2008, 12:15 PM
I have a router mounted for engraving. and would like to run a G1 in IPM??
Old 12-23-2008, 12:52 PM
Mike,
Is your controller a Fanuc 6 MB?
If it is use the G-codes noted in my prior post for Machine center, not Lathe!
BTW if you have a manual and can copy / scan / e-mail the Table of contents, I'll point you to the section that covers this.
All controllers are the same in Principle, they just use different names for similar functions and some have special functions.
All should be described in your documentation. If you don't have it then that is the first thing to get!!
Then if you have questions other can help if you send the info...
JimW
Last edited by jimwymz; 12-23-2008 at 12:58 PM. Reason: Spoke before I looked at theorginal post
Old 12-23-2008, 01:39 PM
I was wondering.
Is it possible to use G31.
Stefan Vendin
Old 12-23-2008, 02:02 PM
I am pretty sure that it is in g94 as a default because that is how I always program when using the machine spindle. I cannot get it to run in a feedrate of any kind without the machine spindle running. Currently I have been using a blank toolholder and let it run 20rpm(S20M3).
Old 12-23-2008, 02:16 PM
Like I said. It can't be done.It's a safety thing.
Stefan Vendin
Old 12-23-2008, 02:44 PM
I have been waiting for a chance to write this "Get a Haas".
I just checked: G98 G01 X-5. F5. works with the spindle stationary.
Surely there must be some way to make your machine do the same.
  #11   Ban this user!
Old 12-23-2008, 05:11 PM
gridley51 is on a distinguished road
There may be a parameter that puts a feedhold on until the spindle is up to speed.
Old 12-23-2008, 05:28 PM
Al_The_Man's Avatar
Normally the CNC side does not look at the spindle unless a G code for CSF or rigid tapping, feed/rev etc, and then it looks at/reads the spindle encoder.
Otherwise all M,S,T, codes are programmed through the PMC.
So it depends on the MTB as to what/how the feed rate reacts to the spindle not running when other than the above commands are issued.
Need Help!- Feed Rate and Spindle Speed chart? jeffmorris DIY-CNC Router Table Machines 3 06-01-2008 09:42 PM
CNC feed rate and spindle speed misc.garfield General CNC (Mill and Lathe) Control Software (NC) 5 01-29-2008 05:20 PM
Feed (G01) with spindle off? ghyman Machine Problems, Solutions , Wireless DNC, serial port 9 02-06-2007 06:22 AM
Spindle speed & feed rate on a Taig Stuff-Builder Taig Mills & Lathes 5 08-29-2005 05:01 PM
Spindle Speed & Feed Rates - Question Moondog DIY-CNC Router Table Machines 1 07-23-2004 06:24 PM
