Old 12-20-2008, 08:54 PM
bubbasrus's Avatar
bubbasrus is on a distinguished road
X extreme limit alarm, will not move
HI I'm new here ;My Sharp 12 x24 w/ FANUC Oi Mate -MB control won't move..
I rapided into X+ and it will not let me move it out .Is there a short cut out of this or do I have to enter paramiter changes to move ...any advice would be appreciated
Old 12-21-2008, 02:30 AM
triumph406 is on a distinguished road
I do the same on my Le Blond RMC55 once in a while, the solution at least for me is to power the machine down, remove the machine covers, and manually turn the leadscrew until it's off the limit switch, that should do it.
Old 12-21-2008, 04:04 AM
ragman is on a distinguished road
Turn your control off. Then, while pressing "P" and "Cancel" buttons at the same time, turn the control back on.Hold the 2 buttons in for 5 seconds or so.
You should then be able to move the X axis out of O/T once the control starts up again.
Old 12-21-2008, 09:15 AM
bubbasrus's Avatar
Thanks I'll try the P & cancel thing first but , the P button is a shift selection only not a direct key function.....if I need to remove the covers I'll try that too. I've had this machine 4 yrs. sence new the only problem I've had is bad wire conectors.& bad crimps everywhere..Does everyone have bad service ,only over the phone help,with new machines?????
Old 12-21-2008, 04:17 PM
cncdiag is on a distinguished road
Does this machine have a hard limit remove switch?
Most machines have a switch that bypasses the hard overtravel switches.
If it does, turn the switch on then jog off the overtravel.
Old 12-22-2008, 09:44 PM
bubbasrus's Avatar
Thumbs up
I don't know, but I will look in the manualls....thx..
Old 12-22-2008, 10:40 PM
bubbasrus's Avatar
Dislexia is a way of life
I'd rather feel stupid then be stupid.... My Sharp manual (not FANUC manual) has a discription for that wierd looking button called a 2nd overtravel limit switch release .HUMMMMMMM.holding this button releases the lock on traveling so I could move that table back to operating range....thanks to all for ideas , maybe I can return the favor....BKF
Need Help!- Bridgeport EZTRAK Alarm: commanded X-axis move too far positive Pribbs Bridgeport and Hardinge Mills 4 01-23-2009 08:34 AM
Need Help!- Alarm: commanded X-axis move too far positive JonMatear Bridgeport and Hardinge Mills 3 08-06-2008 08:41 AM
TM-1 Y axis limit switch alarm jwknow Haas Mills 2 10-26-2007 03:53 PM
extreme axis limit bghowland Bridgeport and Hardinge Mills 5 09-18-2006 07:05 PM
ALARM!!! "Commanded X Axis move too far / Positive" aimeahz Bridgeport and Hardinge Mills 6 04-20-2006 05:51 PM
